PlayStation Vita 3G Antenna Cable Replacement
  1. PlayStation Vita 3G Antenna Cable Replacement, Case Separation: step 1, image 1 of 2 PlayStation Vita 3G Antenna Cable Replacement, Case Separation: step 1, image 2 of 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita 3G Antenna Cable Replacement: step 2, image 1 of 3 PlayStation Vita 3G Antenna Cable Replacement: step 2, image 2 of 3 PlayStation Vita 3G Antenna Cable Replacement: step 2, image 3 of 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita 3G Antenna Cable Replacement: step 3, image 1 of 2 PlayStation Vita 3G Antenna Cable Replacement: step 3, image 2 of 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita 3G Antenna Cable Replacement: step 4, image 1 of 3 PlayStation Vita 3G Antenna Cable Replacement: step 4, image 2 of 3 PlayStation Vita 3G Antenna Cable Replacement: step 4, image 3 of 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita 3G Antenna Cable Replacement: step 5, image 1 of 2 PlayStation Vita 3G Antenna Cable Replacement: step 5, image 2 of 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita 3G Antenna Cable Replacement: step 6, image 1 of 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita 3G Antenna Cable Replacement: step 7, image 1 of 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita 3G Antenna Cable Replacement: step 8, image 1 of 1
    • Separate the front and rear cases.
  9. PlayStation Vita 3G Antenna Cable Replacement, 3G Antenna Cable: step 9, image 1 of 1
    • Using the pointy end of a spudger, gently pry the 3G antenna cable off of the wireless card.
  10. PlayStation Vita 3G Antenna Cable Replacement: step 10, image 1 of 1
    • Using the pointy end of a spudger, gently pry the 3G antenna cable off the right button board.
    • Deroute the 3G antenna cable out of the casing and remove it.
2 other people completed this guide.
Brittany McCrigler
89,051 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,523 Guides authored
One Comment
I need mine fixed because it has came out but it isn’t a wire it is like a orange thin thing and it won’t clip back in
Jacob Gaming videos 123 - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 43
All Time: 7,781
