PlayStation Vita Directional Pad Replacement
  1. PlayStation Vita Directional Pad Replacement, Case Separation: step 1, image 1 of 2 PlayStation Vita Directional Pad Replacement, Case Separation: step 1, image 2 of 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Directional Pad Replacement: step 2, image 1 of 3 PlayStation Vita Directional Pad Replacement: step 2, image 2 of 3 PlayStation Vita Directional Pad Replacement: step 2, image 3 of 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Directional Pad Replacement: step 3, image 1 of 2 PlayStation Vita Directional Pad Replacement: step 3, image 2 of 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Directional Pad Replacement: step 4, image 1 of 3 PlayStation Vita Directional Pad Replacement: step 4, image 2 of 3 PlayStation Vita Directional Pad Replacement: step 4, image 3 of 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Directional Pad Replacement: step 5, image 1 of 2 PlayStation Vita Directional Pad Replacement: step 5, image 2 of 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Directional Pad Replacement: step 6, image 1 of 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Directional Pad Replacement: step 7, image 1 of 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Directional Pad Replacement: step 8, image 1 of 1
    • Separate the front and rear cases.
  9. PlayStation Vita Directional Pad Replacement, Left Shoulder Button: step 9, image 1 of 3 PlayStation Vita Directional Pad Replacement, Left Shoulder Button: step 9, image 2 of 3 PlayStation Vita Directional Pad Replacement, Left Shoulder Button: step 9, image 3 of 3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  10. PlayStation Vita Directional Pad Replacement: step 10, image 1 of 2 PlayStation Vita Directional Pad Replacement: step 10, image 2 of 2
    • Remove the translucent, plastic left shoulder button cover.
  11. PlayStation Vita Directional Pad Replacement: step 11, image 1 of 3 PlayStation Vita Directional Pad Replacement: step 11, image 2 of 3 PlayStation Vita Directional Pad Replacement: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  12. PlayStation Vita Directional Pad Replacement: step 12, image 1 of 2 PlayStation Vita Directional Pad Replacement: step 12, image 2 of 2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
  13. PlayStation Vita Directional Pad Replacement, Left Button Board: step 13, image 1 of 2 PlayStation Vita Directional Pad Replacement, Left Button Board: step 13, image 2 of 2
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
  14. PlayStation Vita Directional Pad Replacement: step 14, image 1 of 3 PlayStation Vita Directional Pad Replacement: step 14, image 2 of 3 PlayStation Vita Directional Pad Replacement: step 14, image 3 of 3
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
  15. PlayStation Vita Directional Pad Replacement: step 15, image 1 of 2 PlayStation Vita Directional Pad Replacement: step 15, image 2 of 2
    Buy
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  16. PlayStation Vita Directional Pad Replacement: step 16, image 1 of 2 PlayStation Vita Directional Pad Replacement: step 16, image 2 of 2
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  17. PlayStation Vita Directional Pad Replacement: step 17, image 1 of 2 PlayStation Vita Directional Pad Replacement: step 17, image 2 of 2
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
  18. PlayStation Vita Directional Pad Replacement: step 18, image 1 of 3 PlayStation Vita Directional Pad Replacement: step 18, image 2 of 3 PlayStation Vita Directional Pad Replacement: step 18, image 3 of 3
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
  19. PlayStation Vita Directional Pad Replacement: step 19, image 1 of 3 PlayStation Vita Directional Pad Replacement: step 19, image 2 of 3 PlayStation Vita Directional Pad Replacement: step 19, image 3 of 3
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
  20. PlayStation Vita Directional Pad Replacement, Directional Pad: step 20, image 1 of 3 PlayStation Vita Directional Pad Replacement, Directional Pad: step 20, image 2 of 3 PlayStation Vita Directional Pad Replacement, Directional Pad: step 20, image 3 of 3
    Buy
    • Using tweezers, peel up and remove the directional pad.
9 other people completed this guide.
Brittany McCrigler
89,051 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,523 Guides authored
One Comment
I read this guide from the first to the20th step I haven't tried it yet though
brandon abney - Reply
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 94
All Time: 16,561
