PlayStation Vita Left Button Board Replacement
  1. PlayStation Vita Left Button Board Replacement, Case Separation: step 1, image 1 of 2 PlayStation Vita Left Button Board Replacement, Case Separation: step 1, image 2 of 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Left Button Board Replacement: step 2, image 1 of 3 PlayStation Vita Left Button Board Replacement: step 2, image 2 of 3 PlayStation Vita Left Button Board Replacement: step 2, image 3 of 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Left Button Board Replacement: step 3, image 1 of 2 PlayStation Vita Left Button Board Replacement: step 3, image 2 of 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Left Button Board Replacement: step 4, image 1 of 3 PlayStation Vita Left Button Board Replacement: step 4, image 2 of 3 PlayStation Vita Left Button Board Replacement: step 4, image 3 of 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Left Button Board Replacement: step 5, image 1 of 2 PlayStation Vita Left Button Board Replacement: step 5, image 2 of 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Left Button Board Replacement: step 6, image 1 of 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Left Button Board Replacement: step 7, image 1 of 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Left Button Board Replacement: step 8, image 1 of 1
    • Separate the front and rear cases.
  9. PlayStation Vita Left Button Board Replacement, Left Shoulder Button: step 9, image 1 of 3 PlayStation Vita Left Button Board Replacement, Left Shoulder Button: step 9, image 2 of 3 PlayStation Vita Left Button Board Replacement, Left Shoulder Button: step 9, image 3 of 3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  10. PlayStation Vita Left Button Board Replacement: step 10, image 1 of 2 PlayStation Vita Left Button Board Replacement: step 10, image 2 of 2
    • Remove the translucent, plastic left shoulder button cover.
  11. PlayStation Vita Left Button Board Replacement: step 11, image 1 of 3 PlayStation Vita Left Button Board Replacement: step 11, image 2 of 3 PlayStation Vita Left Button Board Replacement: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  12. PlayStation Vita Left Button Board Replacement: step 12, image 1 of 2 PlayStation Vita Left Button Board Replacement: step 12, image 2 of 2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
  13. PlayStation Vita Left Button Board Replacement, Left Button Board: step 13, image 1 of 2 PlayStation Vita Left Button Board Replacement, Left Button Board: step 13, image 2 of 2
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
  14. PlayStation Vita Left Button Board Replacement: step 14, image 1 of 3 PlayStation Vita Left Button Board Replacement: step 14, image 2 of 3 PlayStation Vita Left Button Board Replacement: step 14, image 3 of 3
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
  15. PlayStation Vita Left Button Board Replacement: step 15, image 1 of 2 PlayStation Vita Left Button Board Replacement: step 15, image 2 of 2
    Buy
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  16. PlayStation Vita Left Button Board Replacement: step 16, image 1 of 2 PlayStation Vita Left Button Board Replacement: step 16, image 2 of 2
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  17. PlayStation Vita Left Button Board Replacement: step 17, image 1 of 2 PlayStation Vita Left Button Board Replacement: step 17, image 2 of 2
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
  18. PlayStation Vita Left Button Board Replacement: step 18, image 1 of 3 PlayStation Vita Left Button Board Replacement: step 18, image 2 of 3 PlayStation Vita Left Button Board Replacement: step 18, image 3 of 3
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
  19. PlayStation Vita Left Button Board Replacement: step 19, image 1 of 3 PlayStation Vita Left Button Board Replacement: step 19, image 2 of 3 PlayStation Vita Left Button Board Replacement: step 19, image 3 of 3
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
6 other people completed this guide.
Brittany McCrigler
89,769 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,564 Guides authored
3 Comments
good idea but i need help with the big fat one on the left because it went into water by an accsident and its not moving and its like locked or like jammed. I put it in the boiler for a while and i took it out after then it still was jammed locked.
Morganstutte@hotmail.com - Reply
please can you tell me how to fix the big fat button on the left because water went in it and i tryed putting it in the boiler for a while then i took it out and the button was still not working it like jammed locked it dosn't work. PLEEEEEEAAAAASSSSEEE HEEELLLPPP MEEEEEE!!!!!!!!!!!!!!!!!!
Make a video of it please!!!!
Past 24 Hours: 8
Past 7 Days: 28
Past 30 Days: 115
All Time: 10,457
