Playstation Classic Controller Cord Replacement
  1. Playstation Classic Controller Cord Replacement, Controller Cord: step 1, image 1 of 3 Playstation Classic Controller Cord Replacement, Controller Cord: step 1, image 2 of 3 Playstation Classic Controller Cord Replacement, Controller Cord: step 1, image 3 of 3
    • Turn the controller over so that the screws are facing up.
  2. Playstation Classic Controller Cord Replacement: step 2, image 1 of 1
    • Use a small Phillips #0 screwdriver to remove the eight Xmm screws.
    • Make sure to store the screws in a safe place so they are not lost before reassembly.
  3. Playstation Classic Controller Cord Replacement: step 3, image 1 of 3 Playstation Classic Controller Cord Replacement: step 3, image 2 of 3 Playstation Classic Controller Cord Replacement: step 3, image 3 of 3
    • Use the Jimmy tool to take the back part off and get into the controller.
    • It shouldn’t take too much force to remove the back part. Make sure all screws are taken out beforehand so you avoid hurting yourself or damaging the controller.
  4. Playstation Classic Controller Cord Replacement: step 4, image 1 of 1
    • You will notice that the controller cord is plugged into a Micro USB port on the controller motherboard.
  5. Playstation Classic Controller Cord Replacement: step 5, image 1 of 3 Playstation Classic Controller Cord Replacement: step 5, image 2 of 3 Playstation Classic Controller Cord Replacement: step 5, image 3 of 3
    • To unplug the cord from the controller motherboard, carefully take the cord out from in between the small pegs that it is nestled into.
    • When unplugging the cord, hold the controller so that no significant pressure is being applied to the motherboard that will damage it.
3 other people completed this guide.
Maxwell Webb
631 Reputation
5 Guides authored
Cal Poly, Team S2-G8, Maness Spring 2019 Member of Cal Poly, Team S2-G8, Maness Spring 2019
CPSU-MANESS-S19S2G8
2 Members
22 Guides authored
2 Comments
Will this fix the controller being unresponsive?
Jamal Saeed - Reply
maybe but It depends
enrique bengaura -
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 76
All Time: 5,935
