Redmi Note 9 Pro - Reboots, Power On flex Replacement
Video Overview
Xiaomi Redmi Note 9 Pro restarts - Power On flex replacement
  1. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: step 1, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: step 1, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: step 1, image 3 of 3
    • Warm up the device to soften the adhesive.
    • Use plastic tools and a little isopropyl alcohol to separate the back cover.
  2. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: step 2, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: step 2, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: step 2, image 3 of 3
    • Remove the Phillips screws that secure the plastic cover.
    • Use a plastic opening tool to remove the cover.
  3. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: step 3, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: step 3, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: step 3, image 3 of 3
    • Disconnect the battery.
    • Remove the main cameras.
    • Remove the SIM tray.
  4. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: step 4, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: step 4, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: step 4, image 3 of 3
    • Disconnect all flex cables:
    • Fingerprint sensor flex cable
    • Screen flex cable
    • Main flex cable
    • Coaxial antenna cable
    • Remove the Phillips screws securing the motherboard to the middle frame
    • Remove the motherboard.
  5. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: step 5, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: step 5, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: step 5, image 3 of 3
    • Remove the Fingerprint sensor.
    • Remove the volume buttons plastic cap.
    • Use isopropyl alcohol to easily remove the flex cable.
  6. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: step 6, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: step 6, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: step 6, image 3 of 3
    • Use playing cards to remove the flex cable.
5 other people completed this guide.
ZFix
191,368 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,545 Guides authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 33
Past 30 Days: 217
All Time: 4,246
