Removing Dell Inspiron 1150 RAM
  1. Removing Dell Inspiron 1150 RAM, Removing Dell Inspiron 1150 RAM: step 1, image 1 of 1
    • Turn the laptop so that the bottom is facing up.
    • Locate the panel that has an M on it and two air vents.
  2. Removing Dell Inspiron 1150 RAM: step 2, image 1 of 2 Removing Dell Inspiron 1150 RAM: step 2, image 2 of 2
    • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
    • Put this screw in a bag or easily identifiable place.
    • Remove the panel.
  3. Removing Dell Inspiron 1150 RAM: step 3, image 1 of 3 Removing Dell Inspiron 1150 RAM: step 3, image 2 of 3 Removing Dell Inspiron 1150 RAM: step 3, image 3 of 3
    • After removing the panel, you will see two memory modules.
    • Locate the four spring clips that are holding the memory modules in place.
    • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
    • Gently raise the memory module and lift it out of its socket.
Christopher
8 Reputation
1 Guide authored
Cal Poly, Team 16-2, Maness Spring 2010 Member of Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 5,845
