Removing Numerical Keypad
  1. Removing Numerical Keypad, Removing Numerical Keypad: step 1, image 1 of 1
    • You can do this with most keyboards. I had an older Dell keyboard model L100.
  2. Removing Numerical Keypad: step 2, image 1 of 1
    • Turn the keyboard over and you will see 15 screws. Remove them.
  3. Removing Numerical Keypad: step 3, image 1 of 1
    • Take the keyboard apart. You will find a white rubber sheet under the top part of the keyboard. Cut off the part for the numerical keypad.
  4. Removing Numerical Keypad: step 4, image 1 of 1
    • Fasten the top part of the keyboard and take the hacksaw to it. Cut off the numerical keypad part. Do not use power tools because you may produce toxic fumes and even activate fire alarm.
  5. Removing Numerical Keypad: step 5, image 1 of 1
    • On the bottom part of the keyboard, remove the three screws and the metal bar holding the keyboard PCB and fold the plastic sheet so it is out of your way when cutting.
  6. Removing Numerical Keypad: step 6, image 1 of 1
    • Now mark the bottom part of the keyboard for another cut.
  7. Removing Numerical Keypad: step 7, image 1 of 1
    • Cut the bottom part of the keyboard too. Fold or remove the plastic PCB out of the way when cutting.
  8. Removing Numerical Keypad: step 8, image 1 of 1
    • Screw the PCB and the metal bar back on.
  9. Removing Numerical Keypad: step 9, image 1 of 1
    • Assemble the rest of the keyboard, and fold the plastic sheet under your keyboard. Do not cut it because it will render the keyboard useless.
  10. Removing Numerical Keypad: step 10, image 1 of 1
    • Since you have cut the portion of the keyboard with the supporting leg for tilting, supply it with a new leg. You can use a key from the numerical keypad.
  11. Removing Numerical Keypad: step 11, image 1 of 1
    • Tape the key to the keyboad
  12. Removing Numerical Keypad: step 12, image 1 of 1
    • Presto, you are proud owner of a very geeky looking keyboard with even a piece of the PCB sticking out.
4 other people completed this guide.
Stanko Vuleta
242 Reputation
1 Guide authored
9 Comments
this is awful !!
Abdullah Kamran - Reply
This is awesome !!
What kind of saw and sawblade are you using?
Fixer - Reply
Manual hacksaw is probably the best choice. Any power tool is liable to burn the plastic and produce fumes which you don't want to be inhaling.
Stanko Vuleta -
Can i do this to an aluminum extended keyboard usb apple?
appleuserfan - Reply
Judging by the position of the cable, the pcb is placed away from the numerical keypad, so I would guess you should be able to do it.
Stanko Vuleta -
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 60
All Time: 11,225
