iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement
Walter Galan
Walter Galan and 6 other contributors
Last updated on April 11, 2024
45 minutes - 2 hours
Difficult
Introduction
Go to step 1
DVD writer not writing? Get back in business and replace your optical drive.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement, Glass Panel: step 1, image 1 of 3 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement, Glass Panel: step 1, image 2 of 3 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement, Glass Panel: step 1, image 3 of 3
    Tool used on this step:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
  2. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 2, image 1 of 3 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 2, image 2 of 3 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 2, image 3 of 3
    • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
    • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement, Display: step 3, image 1 of 1
    • Remove the eight T10 Torx screws securing the LCD to the outer case.
  4. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 4, image 1 of 3 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 4, image 2 of 3 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 4, image 3 of 3
    • Carefully lay the iMac stand-side down on a flat surface.
    • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
    • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
    • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side. A pencil or pen can be placed under the top edge of the display, parallel to the top edge and extending past the edge of the computer, to keep the first side propped up while lifting the second.
    • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
  5. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 5, image 1 of 2 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 5, image 2 of 2
    • Use a pair of tweezers to pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • On some iMacs this may not be a ribbon cable but four separate, very fine and very fragile wires. Be very careful, if the tweezers slip off the plug, you will very likely pull a wire out of the assembly.
  6. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 6, image 1 of 1
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
  7. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 7, image 1 of 1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be very careful when disconnecting this cable as both the cable connector and logic board socket are extremely fragile. When reconnecting the cable later, use as little force as possible.
  8. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 8, image 1 of 1
    • Lift the display for enough clearance to disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable. The thermal sensor connector socket is very fragile, so be very careful when you connect back the sensor cable.
  9. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 9, image 1 of 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case.
  10. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement, Optical Drive: step 10, image 1 of 1
    • Remove the four T10 Torx screws securing the optical drive to the outer case.
  11. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 11, image 1 of 1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
  12. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 12, image 1 of 2 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 12, image 2 of 2
    • Insert a spudger between the optical drive connector and the optical drive.
    • Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
  13. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 13, image 1 of 1
    • Lift the left edge of the optical drive slightly and pull it away from the right side of the outer case.
    • During reassembly, note that there are two holes in the optical drive face plate into which two stubby plastic posts must engage for proper positioning.
  14. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement, Optical Drive: step 14, image 1 of 2 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement, Optical Drive: step 14, image 2 of 2
    • Peel back the portion of aluminum tape highlighted in red, leaving the rest attached to the black plastic optical drive bracket.
    • It is not necessary to peel all of the EMI tape off the optical drive bracket.
  15. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 15, image 1 of 2 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 15, image 2 of 2
    • Remove the two T10 Torx screws from each side of the optical drive (four screws total).
  16. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 16, image 1 of 3 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 16, image 2 of 3 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 16, image 3 of 3
    • Use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
    • Rotate the optical drive bracket slightly away from the optical drive.
    • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
  17. iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 17, image 1 of 2 iMac Intel 27" EMC 2309 and 2374 Optical Drive Replacement: step 17, image 2 of 2
    • Use the tip of a spudger to peel back the piece of foam tape covering the optical drive thermal sensor.
    • Use the flat end of a spudger to carefully pry the thermal sensor up off the adhesive securing it to the optical drive.
    • If you have a disc or anything else stuck inside your optical drive, we have a guide to fix it.
59 other people completed this guide.
6 Guide Comments
Great tutorial. The recommended T10 Torx Screwdriver was too big - I had to use a T9.
Also, it isn't necessary to unplug the optical drive thermal sensor connector socket on the logic board (Step 10), I just disconnected the optical drive thermal sensor from the drive (Step 17) before removing it.
Ian - Reply
Awesome guide! I bought your suction cups for the front glass, and a toolkit, along with a 2TB HDD to replace the original 1TB drive. It was easy to replace both the optical drive and the HDD with the right tools and this very detailed guide to follow. I have had no problems with the internal cooling fans running fast with the new HDD either. It all came apart easily and seems to have gone back together without any problems as well. A huge help! You saved me several hundred dollars in repair bills. Thank you!
jlgustrowsky - Reply
Great guide, it worked perfect for me. Thanks!
Usue - Reply
I have seen another instructional video I have replaced a HD in an Imac 27 I have all your tools thing is this can be done in my opinion with the computer in its standing position and I will do that for the optical drive soon
orca62 - Reply
Left a comment in the other area too, I used this guide and another linked to it to replace both an HDD and the Superdrive. Perfect Instructions - I was daunted by this task the moment I opened the iMac, but these instructions made it doable. I also replaced the HDD and the Superdrive while in standing position. All I needed were a bunch of Pill Bottles for the screws, my cheap precision ratchet screwdriver set which had the proper size Torx Screw Bit, and an old iPhone Toolkit which had the rest of the things I needed. I used a Palette Knife to remove the sensor. The hardest part is getting the Screen screws back in, because the magnets make it difficult. I can probably do this now with other Model iMacs- This was the second iMac I used your guides to replace the HDD, this was my first Superdrive. Thanks a LOT.
Jonny V - Reply
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 67
All Time: 162,605
