How to Fix Keurig K75 Platinum Brewing System Water Pump Leak
  1. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, Baseplate: step 1, image 1 of 2 How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, Baseplate: step 1, image 2 of 2
    • Before beginning the repair, turn off the brewer and disconnect it from any power source.
    • Move the brewer so that the metal baseplate is easily accessible.
    • Remove the five silver 4 mm Phillips #2 screws from the baseplate.
  2. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: step 2, image 1 of 2 How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: step 2, image 2 of 2
    • Using a spudger, gently pry the metal baseplate from the brewer.
    • Gently set down the baseplate.
  3. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: step 3, image 1 of 2 How to Fix Keurig K75 Platinum Brewing System Water Pump Leak, How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: step 3, image 2 of 2
    • Remove the two silver 4mm Phillips #2 screws that hold the water pump in place.
  4. How to Fix Keurig K75 Platinum Brewing System Water Pump Leak: step 4, image 1 of 1
    • Realign the rubber gasket of the water pump to create a tight fit.
Kristen Temnyk
515 Reputation
3 Guides authored
Cal Poly, Team 20-2, Maness Winter 2013 Member of Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 21,657
