Repairing Quasar Microwave Fan
  1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: step 1, image 1 of 1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Fan: step 2, image 1 of 2 Repairing Quasar Microwave Fan: step 2, image 2 of 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Fan: step 3, image 1 of 2 Repairing Quasar Microwave Fan: step 3, image 2 of 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Fan: step 4, image 1 of 3 Repairing Quasar Microwave Fan: step 4, image 2 of 3 Repairing Quasar Microwave Fan: step 4, image 3 of 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: step 5, image 1 of 2 Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: step 5, image 2 of 2
    • Locate the fan in the newly exposed interior.
    • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
    • If the fan does not spin freely, locate what is jamming the fan and remove it.
  6. Repairing Quasar Microwave Fan: step 6, image 1 of 1
    • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
    • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
Melanie
107 Reputation
2 Guides authored
Cal Poly, Team 2-12, Propen Fall 2012 Member of Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 17
All Time: 1,515
