Repairing a Broken 3-Prong Bodycord for a Fencing Sword
  1. Repairing a Broken 3-Prong Bodycord for a Fencing Sword, Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 1, image 1 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword, Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 1, image 2 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword, Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 1, image 3 of 3
    • Remove the three bolts from the clamshell using a 4mm screwdriver.
    • The clam shell is the hard plastic that protects the internal wiring of the prongs.
    • During reassembly, remember to replace the nuts into their respective holes if they fell out during disassembly.
  2. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 2, image 1 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 2, image 2 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 2, image 3 of 3
    • Remove the top piece of the clamshell.
    • When reassembling, run the wires within the grooves to prevent pinching. If the wires are pinched, they can become damaged.
  3. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 3, image 1 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 3, image 2 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 3, image 3 of 3
    • Mark the wires with a marker in unique patterns to remember their order.
    • In this case, a solid line marks the wire that leads to the prong that is on the outside and near to the middle prong. A dashed line marks the wire leading to the prong that is far from the middle prong.
  4. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 4, image 1 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 4, image 2 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 4, image 3 of 3
    • Lift the wires and prongs out of the clamshell.
  5. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 5, image 1 of 2 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 5, image 2 of 2
    • Pull the shrink wrap down the cord.
    • During reassembly, remember to place the shrink wrap partly into the clamshell.
  6. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 6, image 1 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 6, image 2 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 6, image 3 of 3
    • Be careful to cut all three wires to the same length.
    • Cut the wires below the break point.
    • Usually the break point is at the place where the wires enter the clamshell.
    • Start by cutting small amounts at a time; if you did not cut below the break point, you may cut more of the wire as needed.
  7. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 7, image 1 of 2 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 7, image 2 of 2
    • Loosen the grub screws on each prong using a 2mm screwdriver.
    • You can remove the screws. However, it is easier to just loosen them for reassembly.
  8. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 8, image 1 of 2 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 8, image 2 of 2
    • Remove the wires from the prongs using fingers or needle nose pliers.
    • Set the prongs aside.
    • If pulling straight out is difficult, try a gentle twisting motion inline with the prong.
  9. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 9, image 1 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 9, image 2 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 9, image 3 of 3
    • Peel the wires of the cord apart about 1" (2cm).
    • Use the part of the wire that you cut off as a reference for how far to peel the wires apart.
  10. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 10, image 1 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 10, image 2 of 3 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 10, image 3 of 3
    • Strip the wires, about 1/4", or 5 mm, from the end.
    • Stripping the wires is removing the plastic insulation to expose the inner metal conductor.
    • Repeat for each wire.
  11. Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 11, image 1 of 2 Repairing a Broken 3-Prong Bodycord for a Fencing Sword: step 11, image 2 of 2
    • Twist the loose wire strands together.
    • This step facilitates reinsertion of the wires into the prongs.
To reassemble your bodycord, follow steps 1-8 in reverse order, skipping steps 3 and 6.
To keep your bodycord in working order longer, remember to always pull it out of the sockets by holding onto the plastic, not the wires.
Aidan Fox-Tierney
205 Reputation
1 Guide authored
UC Davis, Team S2-G6, Andersen Winter 2020 Member of UC Davis, Team S2-G6, Andersen Winter 2020
UCD-ANDERSEN-W20S2G6
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 442
