iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, iOpener Heating: step 1, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, iOpener Heating: step 1, image 2 of 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 2, image 1 of 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100ËšC (212ËšF).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 3, image 1 of 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, Alternate iOpener heating method: step 4, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, Alternate iOpener heating method: step 4, image 2 of 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, Front Panel: step 5, image 1 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, Front Panel: step 5, image 2 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, Front Panel: step 5, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 6, image 1 of 1
    Tool used on this step:
    Safety Glasses
    $3.19
    Buy
    • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
    • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
    • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
  7. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 7, image 1 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 7, image 2 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 7, image 3 of 3
    • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
    • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
    • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
  8. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 8, image 1 of 1
    • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
  9. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 9, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 9, image 2 of 2
    • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
  10. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 10, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 10, image 2 of 2
    • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
  11. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 11, image 1 of 1
    • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
  12. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 12, image 1 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 12, image 2 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 12, image 3 of 3
    • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
    • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
    • The adhesive is very strong, and some serious force may be required. Work carefully.
    • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
  13. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 13, image 1 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 13, image 2 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 13, image 3 of 3
    • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  14. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 14, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 14, image 2 of 2
    • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
    • Re-heat the iOpener, and move it to the top edge of the iPad.
  15. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 15, image 1 of 1
    • The next few steps require extreme caution.
    • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
    • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
  16. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 16, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 16, image 2 of 2
    • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
    • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
  17. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 17, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 17, image 2 of 2
    • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
    • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
  18. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 18, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 18, image 2 of 2
    • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
    • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
  19. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 19, image 1 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 19, image 2 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 19, image 3 of 3
    • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
    • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
    • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
  20. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 20, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 20, image 2 of 2
    • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Leave the opening pick wedged underneath the front glass near the home button.
  21. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 21, image 1 of 1
    • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
  22. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 22, image 1 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 22, image 2 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 22, image 3 of 3
    • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
    • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
    • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
    • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
  23. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 23, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 23, image 2 of 2
    • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
    • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
  24. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 24, image 1 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 24, image 2 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 24, image 3 of 3
    • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
    • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
  25. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 25, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 25, image 2 of 2
    • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
    • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
  26. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 26, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 26, image 2 of 2
    • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
    • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
  27. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 27, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 27, image 2 of 2
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
    • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
  28. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, LCD: step 28, image 1 of 1
    • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
  29. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 29, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 29, image 2 of 2
    • Lift the LCD from its long edge closest to the volume buttons and rotate it out of the rear case.
    • Lay the LCD on the front panel as seen in the second picture.
  30. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 30, image 1 of 1
    • Use the edge of a plastic opening tool to flip up the metal retaining clip securing the display data cable to its socket on the logic board.
  31. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 31, image 1 of 1
    • Pull the display data cable out of its socket on the logic board.
    • Do not lift upward on the display data cable connector as you disconnect it.
  32. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 32, image 1 of 1
    • Remove the LCD assembly from the iPad 2.
  33. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, Rear Facing Camera: step 33, image 1 of 1
    • Carefully peel the rubber cover off the metal camera retainer and remove it from the iPad 2.
  34. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 34, image 1 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 34, image 2 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 34, image 3 of 3
    • Remove the following two screws:
    • One 3.3 mm Phillips screw
    • One 2.1 mm Phillips screw
    • Lift the metal retainer clip straight up from its recess in the rear panel.
    • Be sure the small thermal pad is attached to the metal retaining clip as seen in the third picture when replacing the rear facing camera.
  35. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 35, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 35, image 2 of 2
    • Use a plastic opening tool to pry the rear camera connector up from its socket on the control board.
    • Remove the rear facing camera.
  36. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, Power/Mute/Volume Buttons Cable: step 36, image 1 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, Power/Mute/Volume Buttons Cable: step 36, image 2 of 3 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement, Power/Mute/Volume Buttons Cable: step 36, image 3 of 3
    • Once the LCD panel and rear camera are removed, you can begin removing the Power, Mute, Volume cable (hereafter called the PMV cable for short).
    • The PMV cable starts near the end of the control board cable that runs between two of the battery units, and runs in a complicated path along the side and corner of the iPad. (see photos 1 and 2)
    • The end of the PMV cable is wrapped in tape. Begin by removing this tape to expose the silver rectangular connector on the end of the cable. (see photo 3)
    • Use a plastic opening tool or small screwdriver to lift free the rectangular connector.
  37. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 37, image 1 of 1
    • Now you must disassemble the side switches.
    • Remove the 2.1 mm Phillips screw from the volume switch mechanism.
    • Remove the two 5.0 mm Phillips screws from the mute slider mechanism.
    • If you have not already removed the rear camera, do so now.
  38. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 38, image 1 of 1
    • Remove the two 2.5 mm Phillips screws from the back of the power switch mechanism.
    • You can then push in on the power switch (on the exterior of the iPad) to push the mechanism's internal metal plate loose.
    • You can then peel the PMV cable free from the iPad's case, working backwards from the power switch towards the mute switch.
    • Lift free the small metal frame piece supporting the mute and volume switches.
    • Note: The photo shows the mute and volume switch frame being removed before the rear camera and power switch; this is possible but it's probably best to start with the power switch first.
  39. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 39, image 1 of 1
    • The PMV cable itself is a complicated piece with three integrated buttons and a switch slider.
    • You will need to carefully peel off the old cable free from the ipad frame and the two metal supports (one for the power switch, one for the mute and volume switches).
    • Note that each button is held in place with a tiny bit of adhesive. Use a plastic opening tool or small screwdriver to lift them free.
  40. iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 40, image 1 of 2 iPad 2 Wi-Fi Power/Mute/Volume Buttons Cable Replacement: step 40, image 2 of 2
    • Now assemble the replacement PMV cable to the two metal brackets.
    • Each button has on its underside two tiny black plastic pegs which fit into holes in the metal frames, to ensure the proper fit. Make sure to line these up properly when attaching the cable to the metal frames. The reassembled cable should look as shown in the figures.
    • Install the new cable working from the power switch back towards the mute and volume switches and then to the cable connector, snaking the PMV cable along its complicated path.
    • The replacement part should have adhesive patches to hold the cable in place.
    • Attaching the rectangular cable connector is tricky as there is little clearance from the edge of the iPad case. It may be helpful to use a plastic opening tool to push it gently until it snaps into place.
114 other people completed this guide.
Marshall in Baltimore
3,183 Reputation
1 Guide authored
6 Comments
Successfully completed this guide. Thanks.
musstafaa - Reply
Hi, we have an iPad 2 in for repair and needs a new power button assembly. Thing is the ribbon is different from a standard iPad 2. There are subtle differences in the inside too. It is definitely a genuine iPad, and has same model numbers. Anyone come across this before?
iPhoneSurgery - Reply
Chris, I have the same problem with power ribbon cable it's not the one everyone is selling, did you manage to find a source who sold the correct part?
David -
Completed this guide thank you. Just want to point out that there are two cables for the iPad 2, making sure that you have the right one is very important. Be very careful around the camera area of the iPad too this is very tricky and there are no pictures of this part, wish I had done some now to upload for others, but I'm sure that I'll have another to do before to long and I will then. One main tip... Don't stick anything down till you've got everything secure as removing the the tape is very tricky once stuck and you don't want to be replacing this again...
Roberto Enrieu - Reply
Beware of fake versions of this cable 821-1151-A from many suppliers. The Hall Effect magnetic switch will then not work because the printed circuit traces on the cable are incorrect. The fake cable can be identified by an ohmmeter showing the two contacts for the Hall chip farthest from the cable edge to be shorted together.
geoffrey - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 84,271
