Introduction
Use this guide to install a new GPU card.
Unplug your iMac's AC cord along with any peripheral devices.
Lay your iMac face-down on a soft, clean surface as shown.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door.
Gently slide the black plastic RAM pull tab out from the RAM slot.
Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay.
Tool used on this step:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the following four screws:
One 9.3 mm T10 Torx screw with a large head
Three 9.3 mm T10 Torx screws with a normal sized head
Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
In the proceeding steps, you will disconnect the following cables:
SD Board
Left/Right Speaker and Microphone
Audio Port
Wi-Fi Antenna
Right Temperature Sensor, Bluetooth/Ambient Light Sensor/Camera/Left Temperature, and Hard Drive Fan
CPU Fan/Ambient Temperature and Power Button
IR Sensor
One 9.3 mm T10 coarse-threaded screw
One 25 mm T10 coarse-threaded screw
Two 22 mm fine-threaded screws
Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-out and AC-in cables still attaching it to the iMac.
Disconnect the DC-out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-in connector away from the power supply.
Remove the strip of tape securing the GPU thermal sensor cable to the logic board.
Remove the four 6.5 mm T8 Torx screws securing the GPU heat sink to the GPU.
It may be necessary to use a #1 screwdriver to hold the sockets on the GPU heat sink stationary as you loosen the T8 Torx screws.
85 other people completed this guide.
22 Comments
hi! please tell me what type of grafic card is usen in i macs? i know AGP PCI standars but i t is not them
tnks
Hi all, I'm new to computer repair, basically I just want to save my mac. It appears that the graphics card has gone out (it's about 5 yrs. old). Where can I find a good replacement and what would be an appropriate price range? Also, do you have any additional tips for physically replacing it. How can I tell if I need the whole piece or just a section of it? I have seen prices range from $4.00 - $500.00.
Please help!
DEE
Hi There, mine is a late 2011 model iMac desktop and I'm having trouble with the display screen. It's coming up with pink and yellow vertical strips. The tech says it could be graphics card. The online spec for my late 2011 model iMac suggests it is - (AMD Radeon HD 6750M graphics processor with 512MB of GDDR5 memory). Can you please tell me if that's right. Thank You.
it is "AMD Radeon HD 6750M 512 MB" you can click the apple logo in the top left then, "About This Mac" then, check under "Graphics:".
