Replacing the capacitor and triac on the "accelerator pedal" of a sewing machine
  1. Replacing the capacitor and triac on the "accelerator pedal" of a sewing machine, Capacitor and triac: step 1, image 1 of 1
    • Disconnect the powerplug!
    • Open the device. Compare with this wiki. You may have to look for the catches or the screws with which it is locked. On this model, the pedal is only engaged. Pay attention to the moving plate and the spring.
    • Expose the circuit board so that you can reach the underside to desolder the components.
    • This is the triac. Desolder its three legs on the underside. These instructions tell you how to check it. Replace it if necessary.
    • Here are two capacitors. Read their capacitance. Desolder them and measure them with a suitable digital voltmeter. Replace them if necessary.
    • Look for the same type, usually MKP, the same dimensions, the same voltage and the class, usually X2.
    • Fuse. Measure its continuity and replace if necessary. Remember that a blown fuse usually has a reason.
Finish Line
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
CS.Singen
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 45
All Time: 216
