Retina MacBook 2015 Logic Board Replacement
  1. Retina MacBook 2015 Logic Board Replacement, Unfasten the lower case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Retina MacBook 2015 Logic Board Replacement: step 2, image 1 of 3 Retina MacBook 2015 Logic Board Replacement: step 2, image 2 of 3 Retina MacBook 2015 Logic Board Replacement: step 2, image 3 of 3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  3. Retina MacBook 2015 Logic Board Replacement: step 3, image 1 of 1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  4. Retina MacBook 2015 Logic Board Replacement: step 4, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 4, image 2 of 2
    • Lift the upper case and display together from the front edge and raise it to about a 45Ëš angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
  5. Retina MacBook 2015 Logic Board Replacement: step 5, image 1 of 3 Retina MacBook 2015 Logic Board Replacement: step 5, image 2 of 3 Retina MacBook 2015 Logic Board Replacement: step 5, image 3 of 3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  6. Retina MacBook 2015 Logic Board Replacement: step 6, image 1 of 1
    • Close the MacBook and carefully flip it upside-down.
  7. Retina MacBook 2015 Logic Board Replacement: step 7, image 1 of 1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  8. Retina MacBook 2015 Logic Board Replacement: step 8, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 8, image 2 of 2
    Buy
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  9. Retina MacBook 2015 Logic Board Replacement: step 9, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 9, image 2 of 2
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
  10. Retina MacBook 2015 Logic Board Replacement: step 10, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 10, image 2 of 2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  11. Retina MacBook 2015 Logic Board Replacement: step 11, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 11, image 2 of 2
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  12. Retina MacBook 2015 Logic Board Replacement: step 12, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 12, image 2 of 2
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
  13. Retina MacBook 2015 Logic Board Replacement: step 13, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 13, image 2 of 2
    Battery Blocker
    $3.99
    Buy
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  14. Retina MacBook 2015 Logic Board Replacement: step 14, image 1 of 1
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • Some variations of this model may use a Phillips #00 screw.
    • 3.5 mm T5 Torx screw
  15. Retina MacBook 2015 Logic Board Replacement: step 15, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 15, image 2 of 2
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
  16. Retina MacBook 2015 Logic Board Replacement: step 16, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 16, image 2 of 2
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  17. Retina MacBook 2015 Logic Board Replacement: step 17, image 1 of 1
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
  18. Retina MacBook 2015 Logic Board Replacement, Retina MacBook 2015 Lower Case Assembly Removal: step 18, image 1 of 2 Retina MacBook 2015 Logic Board Replacement, Retina MacBook 2015 Lower Case Assembly Removal: step 18, image 2 of 2
    Buy
    • Use tweezers to peel back the tape covering the display cable connector.
  19. Retina MacBook 2015 Logic Board Replacement: step 19, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 19, image 2 of 2
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
  20. Retina MacBook 2015 Logic Board Replacement: step 20, image 1 of 1
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
  21. Retina MacBook 2015 Logic Board Replacement: step 21, image 1 of 3 Retina MacBook 2015 Logic Board Replacement: step 21, image 2 of 3 Retina MacBook 2015 Logic Board Replacement: step 21, image 3 of 3
    iOpener
    $12.99
    Buy
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If it doesn't separate easily, heat the cable and/or the case directly beneath it with a hair dryer or iOpener to soften the adhesive, and try again.
  22. Retina MacBook 2015 Logic Board Replacement: step 22, image 1 of 1
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap.
    • The flap must remain closed when the cable is reinserted during reassembly. Carefully line up the cable with the gold contacts facing down, and gently slide it into the connector. Take care not to crimp or damage the cable. When fully inserted, the indentations on the sides should not be visible.
  23. Retina MacBook 2015 Logic Board Replacement: step 23, image 1 of 1
    • Separate the upper case assembly from the lower case assembly.
  24. Retina MacBook 2015 Logic Board Replacement, Logic Board: step 24, image 1 of 3 Retina MacBook 2015 Logic Board Replacement, Logic Board: step 24, image 2 of 3 Retina MacBook 2015 Logic Board Replacement, Logic Board: step 24, image 3 of 3
    Buy
    • Use tweezers to peel up the tape covering the two ZIF connectors—one for the right speaker cable, and one for the audio jack board cable.
  25. Retina MacBook 2015 Logic Board Replacement: step 25, image 1 of 3 Retina MacBook 2015 Logic Board Replacement: step 25, image 2 of 3 Retina MacBook 2015 Logic Board Replacement: step 25, image 3 of 3
    • Use the point of a spudger to flip up both ZIF connector retaining flaps.
  26. Retina MacBook 2015 Logic Board Replacement: step 26, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 26, image 2 of 2
    • Carefully pull straight back on the two pieces of tape you just peeled up to disconnect the two ribbon cables.
  27. Retina MacBook 2015 Logic Board Replacement: step 27, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 27, image 2 of 2
    • Use the point of a spudger to peel up the foam pad covering the two antenna connectors.
  28. Retina MacBook 2015 Logic Board Replacement: step 28, image 1 of 3 Retina MacBook 2015 Logic Board Replacement: step 28, image 2 of 3 Retina MacBook 2015 Logic Board Replacement: step 28, image 3 of 3
    • Insert one arm of your angled tweezers under the metal neck of the first antenna connector and pry up to disconnect it.
    • The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.
  29. Retina MacBook 2015 Logic Board Replacement: step 29, image 1 of 3 Retina MacBook 2015 Logic Board Replacement: step 29, image 2 of 3 Retina MacBook 2015 Logic Board Replacement: step 29, image 3 of 3
    • Pry up the second antenna connector to disconnect it.
  30. Retina MacBook 2015 Logic Board Replacement: step 30, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 30, image 2 of 2
    • Use a spudger to disconnect the left speaker cable connector by prying it straight up from the logic board.
  31. Retina MacBook 2015 Logic Board Replacement: step 31, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 31, image 2 of 2
    • Use a spudger to flip up the retaining flap on the trackpad cable ZIF connector.
  32. Retina MacBook 2015 Logic Board Replacement: step 32, image 1 of 2 Retina MacBook 2015 Logic Board Replacement: step 32, image 2 of 2
    • Disconnect the trackpad cable from the logic board by gently pulling it straight out of its connector.
    • During reassembly, check that your ZIF connector flaps are flipped up before reinserting their cables.
  33. Retina MacBook 2015 Logic Board Replacement: step 33, image 1 of 1
    • Remove the single 3.5 mm T5 Torx screw securing the logic board to the lower case.
  34. Retina MacBook 2015 Logic Board Replacement: step 34, image 1 of 3 Retina MacBook 2015 Logic Board Replacement: step 34, image 2 of 3 Retina MacBook 2015 Logic Board Replacement: step 34, image 3 of 3
    • Flip up the front edge of the logic board.
    • Handle the logic board only by its edges.
    • Lift and detach the EMI tape securing the logic board to the lower case.
    • If the tape feels stuck, heat it with a hair dryer or iOpener to soften the adhesive.
    • Reattach the tape securely during reassembly.
  35. Retina MacBook 2015 Logic Board Replacement: step 35, image 1 of 1
    • Remove the logic board.
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
45 other people completed this guide.
Jeff Suovanen
429,963 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,628 Guides authored
6 Comments
While this may be difficult for some, a little patience and a light touch make this easier than it first appears.
Steve - Reply
successfully change my motherboard..Thanks for the guide
hanifah jusoh - Reply
Good Guide, easy to follow. Well Done!
Marco Mancin - Reply
if my 2015 12" macbook 1.3 ghz with 512 gb is slow will swapping out the board make it quick again?
daniel s - Reply
Hi Daniel. Swapping the board is more of a last-resort if something is broken. There are many possible reasons your MacBook is running slow. Running much newer software, having bloatware installed, and a variety of smaller factors all play into the speed of your laptop. Look around online for ways to clean up your drive!
Clay Eickemeyer -
Past 24 Hours: 7
Past 7 Days: 81
Past 30 Days: 378
All Time: 58,428
