SCUF Reflex Joystick Replacement
  1. SCUF Reflex Joystick Replacement, Remove the middle trim: step 1, image 1 of 1
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips.
    • Loosen the rest of the clips and take the middle trim out.
  2. SCUF Reflex Joystick Replacement, Remove L1 and R1: step 2, image 1 of 3 SCUF Reflex Joystick Replacement, Remove L1 and R1: step 2, image 2 of 3 SCUF Reflex Joystick Replacement, Remove L1 and R1: step 2, image 3 of 3
    • Use a tool to pop the R1 and L1 buttons off of the controller.
  3. SCUF Reflex Joystick Replacement, Unscrew the grips: step 3, image 1 of 2 SCUF Reflex Joystick Replacement, Unscrew the grips: step 3, image 2 of 2
    • Unscrew and remove the screw from the bottom of each grip.
  4. SCUF Reflex Joystick Replacement, Unscrew behind L1 and R1: step 4, image 1 of 1
    • Unscrew the screws behind the L1 and R1 buttons.
  5. SCUF Reflex Joystick Replacement, Pull the joysticks off: step 5, image 1 of 2 SCUF Reflex Joystick Replacement, Pull the joysticks off: step 5, image 2 of 2
    • Pull the joysticks off of the controller.
  6. SCUF Reflex Joystick Replacement, Pull the scuff buttons off: step 6, image 1 of 1
    • Pull the scuff buttons off the back of the controller by sliding them down.
  7. SCUF Reflex Joystick Replacement, Remove the rear case: step 7, image 1 of 2 SCUF Reflex Joystick Replacement, Remove the rear case: step 7, image 2 of 2
    • Slide the prying tool down the edge of the rear casing of the controller to remove the rear case.
    • Be sure to deal with all the clips!
  8. SCUF Reflex Joystick Replacement, Slide the battery out: step 8, image 1 of 2 SCUF Reflex Joystick Replacement, Slide the battery out: step 8, image 2 of 2
    • Slide the battery out of the controller. It is a big grey box.
  9. SCUF Reflex Joystick Replacement, Unplug the battery: step 9, image 1 of 1
    • Unplug the battery to finish removing the battery from the controller.
  10. SCUF Reflex Joystick Replacement, Take the battery bracket out: step 10, image 1 of 2 SCUF Reflex Joystick Replacement, Take the battery bracket out: step 10, image 2 of 2
    • Unscrew the screw on the back of the controller to remove the battery bracket.
  11. SCUF Reflex Joystick Replacement, Desolder the ribbon cables: step 11, image 1 of 2 SCUF Reflex Joystick Replacement, Desolder the ribbon cables: step 11, image 2 of 2
    • Use a soldering iron to desolder the ribbon cables on the motherboard.
  12. SCUF Reflex Joystick Replacement: step 12, image 1 of 1
    • Unplug these four cables from the motherboard.
  13. SCUF Reflex Joystick Replacement: step 13, image 1 of 1
    • Use the soldering iron to desolder the black and red wires off of the motherboard.
  14. SCUF Reflex Joystick Replacement: step 14, image 1 of 1
    • Remove the motherboard and the battery bracket from the controller to expose the joystick component.
  15. SCUF Reflex Joystick Replacement: step 15, image 1 of 1
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Use the soldering iron and the desoldering pump to desolder the 14 connections for the component.
  16. SCUF Reflex Joystick Replacement: step 16, image 1 of 1
    • Remove the component from the motherboard.
  17. SCUF Reflex Joystick Replacement: step 17, image 1 of 2 SCUF Reflex Joystick Replacement: step 17, image 2 of 2
    • Put the new component on the motherboard.
    • Use the soldering iron to connect the new component to the motherboard.
0 Comments
Past 24 Hours: 12
Past 7 Days: 72
Past 30 Days: 329
All Time: 3,109
