SEAT Cordoba II (2002-2009) Air Filter Replacement
  1. SEAT Cordoba II (2002-2009) Air Filter Replacement, Remove the two indicated screws: step 1, image 1 of 1
    • Unscrew the two phillips head screws. Use the reversible screwdriver that came with the car.
  2. SEAT Cordoba II (2002-2009) Air Filter Replacement, Open the cover: step 2, image 1 of 2 SEAT Cordoba II (2002-2009) Air Filter Replacement, Open the cover: step 2, image 2 of 2
    • Pull the cover up and slightly to the right.
    • Here we have to replace the filter. Lift the filter up. It comes off without difficulty.
  3. SEAT Cordoba II (2002-2009) Air Filter Replacement, Clean and replace: step 3, image 1 of 2 SEAT Cordoba II (2002-2009) Air Filter Replacement, Clean and replace: step 3, image 2 of 2
    • Clean all of the rubbish and insects that are inside.
    • Place the new filter, fitting the rubber contour with the gap.
  4. SEAT Cordoba II (2002-2009) Air Filter Replacement, Replacing the cover and the screws: step 4, image 1 of 3 SEAT Cordoba II (2002-2009) Air Filter Replacement, Replacing the cover and the screws: step 4, image 2 of 3 SEAT Cordoba II (2002-2009) Air Filter Replacement, Replacing the cover and the screws: step 4, image 3 of 3
    • Fit the two tabs in their places.
    • Once you've done that, put the two screws into their places and tightly screw them in. Finally, check to see that they are completely screwed in.
Finish Line
2 other people completed this guide.
Special thanks to these translators:
es en
100%
Mr. Bean is helping us fix the world! Want to contribute?
Start translating ›
Jonatan M
530 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 11
Past 7 Days: 45
Past 30 Days: 250
All Time: 5,695
