Samsung Chromebook 3 Battery Replacement
  1. Samsung Chromebook 3 Battery Replacement, Bottom Case: step 1, image 1 of 2 Samsung Chromebook 3 Battery Replacement, Bottom Case: step 1, image 2 of 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Battery Replacement: step 2, image 1 of 3 Samsung Chromebook 3 Battery Replacement: step 2, image 2 of 3 Samsung Chromebook 3 Battery Replacement: step 2, image 3 of 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Battery Replacement: step 3, image 1 of 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Battery Replacement, Battery: step 4, image 1 of 2 Samsung Chromebook 3 Battery Replacement, Battery: step 4, image 2 of 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Battery Replacement: step 5, image 1 of 2 Samsung Chromebook 3 Battery Replacement: step 5, image 2 of 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Battery Replacement: step 6, image 1 of 1
    • Lift the battery up and out from the case.
5 other people completed this guide.
Austin Blakely
19,711 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,528 Guides authored
One Comment
Can you fix my chromebook
Peter Hancocks - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,550
