Samsung Chromebook 3 Bottom Case Replacement
  1. Samsung Chromebook 3 Bottom Case Replacement, Bottom Case: step 1, image 1 of 2 Samsung Chromebook 3 Bottom Case Replacement, Bottom Case: step 1, image 2 of 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Bottom Case Replacement: step 2, image 1 of 3 Samsung Chromebook 3 Bottom Case Replacement: step 2, image 2 of 3 Samsung Chromebook 3 Bottom Case Replacement: step 2, image 3 of 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Bottom Case Replacement: step 3, image 1 of 1
    • Lift the case up and off the device
2 other people completed this guide.
Austin Blakely
19,652 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 710
