Samsung Chromebook Series 3 Bottom Cover Replacement
  1. Samsung Chromebook Series 3 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 3 Samsung Chromebook Series 3 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 3 Samsung Chromebook Series 3 Bottom Cover Replacement, Bottom Cover: step 1, image 3 of 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Bottom Cover Replacement: step 2, image 1 of 3 Samsung Chromebook Series 3 Bottom Cover Replacement: step 2, image 2 of 3 Samsung Chromebook Series 3 Bottom Cover Replacement: step 2, image 3 of 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Bottom Cover Replacement: step 3, image 1 of 3 Samsung Chromebook Series 3 Bottom Cover Replacement: step 3, image 2 of 3 Samsung Chromebook Series 3 Bottom Cover Replacement: step 3, image 3 of 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Bottom Cover Replacement: step 4, image 1 of 3 Samsung Chromebook Series 3 Bottom Cover Replacement: step 4, image 2 of 3 Samsung Chromebook Series 3 Bottom Cover Replacement: step 4, image 3 of 3
    • Pry off the bottom cover using a plastic opening tool.
7 other people completed this guide.
Andrey Radchishin
1,833 Reputation
4 Guides authored
UWT Liner: Group 1 Member of UWT Liner: Group 1
Community
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 57
All Time: 5,988
