Samsung Galaxy S21 Ultra Vibration Motor Replacement
  1. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Heat the back cover: step 1, image 1 of 1
    • Unplug and power off your phone before you begin.
    • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Insert an opening pick: step 2, image 3 of 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Slice the adhesive: step 3, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Slice the adhesive: step 3, image 2 of 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 4, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 4, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 4, image 3 of 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 5, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 5, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 5, image 3 of 3
    • When you slice near the camera assembly, insert only the tip of the opening pick (~ 4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 6, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 6, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 6, image 3 of 3
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~ 3-4 mm) to avoid damaging the power and volume button flex cable.
  7. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the back cover: step 7, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the back cover: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers.
    • Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  8. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Slice the adhesive: step 8, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Slice the adhesive: step 8, image 2 of 2
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  9. Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 9, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 9, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement: step 9, image 3 of 3
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  10. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the charging coil: step 10, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the charging coil: step 10, image 2 of 2
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  11. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the NFC antenna: step 11, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the NFC antenna: step 11, image 2 of 2
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  12. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Unfasten the NFC antenna & charging coil assembly screws: step 12, image 1 of 1
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  13. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the NFC antenna & charging coil assembly: step 13, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the NFC antenna & charging coil assembly: step 13, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the NFC antenna & charging coil assembly: step 13, image 3 of 3
    Buy
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  14. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the battery cable: step 14, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the battery cable: step 14, image 2 of 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Unfasten the loudspeaker assembly screws: step 15, image 1 of 1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the loudspeaker assembly.
  16. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Pry up the loudspeaker assembly: step 16, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Pry up the loudspeaker assembly: step 16, image 2 of 2
    • Insert a spudger into the gap between the top edge of the loudspeaker assembly and the midframe.
    • Use your spudger to pry up the loudspeaker assembly by tilting it downwards.
  17. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the loudspeaker assembly: step 17, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the loudspeaker assembly: step 17, image 2 of 2
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
  18. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the display flex cable: step 18, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the display flex cable: step 18, image 2 of 2
    • If you're not planning to remove the motherboard or to replace the battery, you can skip this step and continue with the next one.
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  19. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the main & interconnect flex cables: step 19, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the main & interconnect flex cables: step 19, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the main & interconnect flex cables: step 19, image 3 of 3
    • Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
  20. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the interconnect flex cable: step 20, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the interconnect flex cable: step 20, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the interconnect flex cable: step 20, image 3 of 3
    Buy
    • Use a spudger to disconnect the interconnect flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the interconnect flex cable.
  21. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the main flex cable: step 21, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the main flex cable: step 21, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the main flex cable: step 21, image 3 of 3
    • Use a spudger to disconnect the main flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the main flex cable.
  22. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Unfasten the earpiece and laser AF module assembly screws: step 22, image 1 of 1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the earpiece speaker and laser AF module assembly.
  23. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the laser AF module and earpiece speaker  flex cable: step 23, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the laser AF module and earpiece speaker  flex cable: step 23, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the laser AF module and earpiece speaker  flex cable: step 23, image 3 of 3
    • Use a spudger to disconnect the laser AF module and earpiece speaker flex cables by prying the connectors straight up from their socket.
  24. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the earpiece speaker and laser AF module assembly: step 24, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the earpiece speaker and laser AF module assembly: step 24, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the earpiece speaker and laser AF module assembly: step 24, image 3 of 3
    Buy
    • Grab the bottom right corner of the earpiece speaker and laser AF module assembly with a pair of blunt nose tweezers and carefully lift it upwards.
    • Remove the earpiece speaker and laser AF module assembly.
  25. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the in-display fingerprint and  antenna flex cables: step 25, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the in-display fingerprint and  antenna flex cables: step 25, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the in-display fingerprint and  antenna flex cables: step 25, image 3 of 3
    • Use a spudger to disconnect the in-display fingerprint and antenna flex cables by prying the connectors straight up from their socket.
    • Carefully bend both connectors to the side to free the motherboard.
    • Do not fold the cables sharply and only bend them to avoid cable damage.
  26. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the front facing camera: step 26, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the front facing camera: step 26, image 2 of 2
    • Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
  27. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the power button flex cable: step 27, image 1 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the power button flex cable: step 27, image 2 of 3 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Disconnect the power button flex cable: step 27, image 3 of 3
    • Use a spudger to disconnect the power button flex cable by prying the connector straight up from its socket.
    • Carefully bend the connector to the side to free the motherboard.
  28. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Unfasten the camera module screw: step 28, image 1 of 1
    • Use a Phillips screwdriver to remove the 3.9 mm-long screw securing the camera module.
  29. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Pry up the motherboard: step 29, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Pry up the motherboard: step 29, image 2 of 2
    • Avoid damaging the flex cables surrounding the motherboard during the following procedure.
    • Insert an spudger underneath the top edge of the motherboard next to the vibration motor.
    • Use your spudger to pry up the motherboard by tilting it downwards and twisting it to the side at the same time.
  30. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the motherboard: step 30, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the motherboard: step 30, image 2 of 2
    • Carefully remove the motherboard.
    • Avoid any abrupt movements during the removal and make sure none of the flex cables are entangled in the motherboard to avoid tearing them.
  31. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Loosen the vibration motor adhesive: step 31, image 1 of 1
    • Prepare an iOpener and apply it to the screen where the front facing camera is located for at least two minutes to loosen the adhesive underneath the vibration motor.
  32. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Pry up the vibration motor: step 32, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Pry up the vibration motor: step 32, image 2 of 2
    Buy
    • Carefully insert one arm of a pair of tweezers underneath the vibration motor connector.
    • Use your tweezers to pry up the vibration motor.
  33. Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the vibration motor: step 33, image 1 of 2 Samsung Galaxy S21 Ultra Vibration Motor Replacement, Remove the vibration motor: step 33, image 2 of 2
    • Use your pair of tweezers to lift the vibration motor out of its recess and remove it.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After you've completed the repair, follow this guide to test your repair.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
2 other people completed this guide.
Dominik Schnabelrauch
206,475 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
One Comment
Help me I need engine only how can I get engine for sumsung s21 ultra
ALLHSN - Reply
Past 24 Hours: 3
Past 7 Days: 39
Past 30 Days: 183
All Time: 2,943
