Samsung Galaxy S22 USB-C Port and Charging Board Replacement
  1. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the SIM card tray: step 1, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the SIM card tray: step 1, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the SIM card tray: step 1, image 3 of 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Heat the bottom edge: step 2, image 1 of 1
    • Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Adhesive information: step 3, image 1 of 2 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Adhesive information: step 3, image 2 of 2
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  4. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Insert an opening pick: step 4, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Insert an opening pick: step 4, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Insert an opening pick: step 4, image 3 of 3
    • Apply a suction handle to the back cover, as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  5. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the bottom adhesive: step 5, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the bottom adhesive: step 5, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the bottom adhesive: step 5, image 3 of 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Heat the left edge: step 6, image 1 of 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  7. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the left adhesive: step 7, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the left adhesive: step 7, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the left adhesive: step 7, image 3 of 3
    • Insert a second opening pick at the bottom left corner.
    • Slide the pick to the bottom of the camera bezel to slice the left adhesive.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in to prevent the adhesive from resealing.
  8. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Heat the right edge: step 8, image 1 of 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
  9. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the right adhesive: step 9, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the right adhesive: step 9, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the right adhesive: step 9, image 3 of 3
    • Insert a third opening pick at the bottom right corner.
    • If the adhesive has resealed, insert the pick closer to the bottom edge.
    • Slide the pick to the top right corner to slice the adhesive.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  10. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Heat the top edge: step 10, image 1 of 1
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  11. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the remaining adhesive: step 11, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the remaining adhesive: step 11, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the remaining adhesive: step 11, image 3 of 3
    • Insert an opening pick in the gap at the top right edge.
    • Slide the pick across the top edge and around the top left corner to slice the remaining adhesive.
    • Only insert the pick up to 4 mm, as you may damage the rear cameras or flash.
  12. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the back cover: step 12, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the back cover: step 12, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the back cover: step 12, image 3 of 3
    Tool used on this step:
    Buy
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • To apply new adhesive, follow this guide.
  13. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the wireless charging coil: step 13, image 1 of 2 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the wireless charging coil: step 13, image 2 of 2
    • Use the pointed end of a spudger to pry and disconnect the wireless charging coil from the motherboard.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  14. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unfasten the wireless charging coil: step 14, image 1 of 1
    • Use your Phillips screwdriver to remove the six 3.5 mm-long screws securing the wireless charging coil.
  15. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unfasten the loudspeaker: step 15, image 1 of 1
    • Use your Phillips screwdriver to remove the seven 3.5 mm screws securing the loudspeaker.
  16. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unclip the loudspeaker: step 16, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unclip the loudspeaker: step 16, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unclip the loudspeaker: step 16, image 3 of 3
    • Insert the pointed end of your spudger between the upper left corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • During reassembly, press around the perimeter of the loudspeaker to engage the clips.
  17. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: step 17, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: step 17, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: step 17, image 3 of 3
    • Grab and remove the wireless charging coil and loudspeaker from the frame.
    • Do not separate the charging coil from the loudspeaker.
  18. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the battery: step 18, image 1 of 2 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the battery: step 18, image 2 of 2
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
  19. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: step 19, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: step 19, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: step 19, image 3 of 3
    • Use the pointed end of your spudger to pry up and disconnect both interconnect cables from the motherboard.
  20. Samsung Galaxy S22 USB-C Port and Charging Board Replacement: step 20, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement: step 20, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement: step 20, image 3 of 3
    • Use the pointed end of your spudger to pry up and disconnect both interconnect cables from the charging board.
  21. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the interconnect cables: step 21, image 1 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the interconnect cables: step 21, image 2 of 3 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the interconnect cables: step 21, image 3 of 3
    • Grab and remove the two interconnect cables from the frame.
    • During reassembly, orient the cables so the "main" ends are toward the top of the phone and the "sub" ends are toward the bottom.
  22. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unfasten the charging board: step 22, image 1 of 1
    • Use your Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  23. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Pry up the charging board: step 23, image 1 of 2 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Pry up the charging board: step 23, image 2 of 2
    • Insert the pointed end of your spudger between the top right of the charging board and the frame.
    • Pry the charging board up from its recess until you can grab it with your fingers.
  24. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging board: step 24, image 1 of 2 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging board: step 24, image 2 of 2
    • Grip the charging board by its corners and slide it out of its recess in the frame.
    • Remove the charging board.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
4 other people completed this guide.
Clay Eickemeyer
68,062 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,529 Guides authored
3 Comments
Just finished this repair and it was fairly simple when you follow the instructions! A replacement adhesive is included with the kit, so no need to buy that separately.
NickMuir - Reply
Does the wireless charger use the charging board for charging? Or is battery charging managed in the main board?
Wade Smith - Reply
I’m based in the uk so unfortunately you cannot supply the charging board. Can anyone recommend somewhere to purchase. There are plenty on eBay but unsure of quality. Thanks
JohnyB - Reply
Past 24 Hours: 24
Past 7 Days: 231
Past 30 Days: 941
All Time: 15,502
