Samsung Galaxy Tab S7 Plus Motherboard Replacement
  1. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Heat the bottom edge: step 1, image 1 of 1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device to loosen the adhesive underneath.
    • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  2. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Screen removal information: step 2, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Screen removal information: step 2, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Screen removal information: step 2, image 3 of 3
    • While you're waiting for the adhesive to loosen, note the following:
    • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
    • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
    • This image shows an example of the display separating from the glass panel.
    • Don't insert the pick more than 3 mm to avoid damaging the display.
  3. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Insert an opening pick: step 3, image 3 of 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the bottom adhesive: step 4, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the bottom adhesive: step 4, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the bottom adhesive: step 4, image 3 of 3
    • Insert a new opening pick into the gap you created.
    • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
  5. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Heat the right edge: step 5, image 1 of 1
    • Apply a heated iOpener to the right edge of the device to loosen the adhesive underneath.
  6. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the bottom-right corner adhesive: step 6, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the bottom-right corner adhesive: step 6, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the bottom-right corner adhesive: step 6, image 3 of 3
    • Rotate the opening pick around the bottom-right corner of the device.
  7. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the right adhesive: step 7, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the right adhesive: step 7, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the right adhesive: step 7, image 3 of 3
    • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
    • Slide the new pick along the right edge of the device towards the top-right corner.
  8. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Heat the top edge: step 8, image 1 of 1
    • Apply a heated iOpener to the top edge of the device to loosen the adhesive underneath.
  9. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the top-right corner adhesive: step 9, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the top-right corner adhesive: step 9, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the top-right corner adhesive: step 9, image 3 of 3
    • Rotate the opening pick around the top-right corner of the device.
  10. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the top adhesive: step 10, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the top adhesive: step 10, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the top adhesive: step 10, image 3 of 3
    • Slide the new pick along the top edge of the device towards the top-left corner.
  11. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Heat the left edge: step 11, image 1 of 1
    • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
  12. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the top-left corner adhesive: step 12, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the top-left corner adhesive: step 12, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the top-left corner adhesive: step 12, image 3 of 3
    • Rotate the opening pick around the top-left corner of the device.
  13. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the left adhesive: step 13, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the left adhesive: step 13, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the left adhesive: step 13, image 3 of 3
    • Slide the new pick along the left edge of the device towards the bottom-left corner.
  14. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the bottom-left corner adhesive: step 14, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the bottom-left corner adhesive: step 14, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Separate the bottom-left corner adhesive: step 14, image 3 of 3
    • Rotate the opening pick around the bottom-left corner of the device.
    • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
  15. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the screen: step 15, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the screen: step 15, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the screen: step 15, image 3 of 3
    Tool used on this step:
    Buy
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the top of the device facing you, pull the screen up and away from you like you're opening a book.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
    • During reassembly:
    • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the display cable: step 16, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the display cable: step 16, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Samsung Galaxy Tab S7 Plus Motherboard Replacement: step 17, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement: step 17, image 2 of 2
    • Use tweezers, or you fingers, to hold the display cable in place.
    • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
    • Take note of the display cable's position; you will need to bend it in the same way when connecting a new screen.
  18. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the screen: step 18, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the screen: step 18, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the screen: step 18, image 3 of 3
    • Remove the screen from the frame.
  19. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Unfasten the frame bracket: step 19, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Unfasten the frame bracket: step 19, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Unfasten the frame bracket: step 19, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the fifty 3 mm-long screws securing the frame bracket to the frame.
    • The third photo has the same screws marked by quadrant. Use this photo during reassembly to help account for all the screws:
    • Bottom left = 9 screws
    • Bottom right = 14 screws
    • Top right = 12 screws
    • Top left = 15 screws
  20. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the frame bracket: step 20, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the frame bracket: step 20, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the frame bracket: step 20, image 3 of 3
    • Lift the frame bracket away from the frame, making sure to thread the display cable through its socket.
  21. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the battery: step 21, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the battery: step 21, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the battery's press connector secured to the motherboard.
  22. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the display cable: step 22, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the display cable: step 22, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the display cable: step 22, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the motherboard.
    • Repeat for the fingerprint sensor cable attached to display cable.
  23. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the display cable: step 23, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the display cable: step 23, image 2 of 2
    • Use your fingers to remove the display cable.
  24. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the daughterboard interconnect cable: step 24, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the daughterboard interconnect cable: step 24, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the daughterboard interconnect cable's press connector secured to the motherboard.
  25. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the keyboard dock port cable: step 25, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the keyboard dock port cable: step 25, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the keyboard dock port cable's press connector secured to the motherboard.
  26. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the front camera: step 26, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the front camera: step 26, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the front camera: step 26, image 3 of 3
    Buy
    • Use the flat end of a spudger to pry up and disconnect the front camera's press connector secured to the motherboard.
    • Use tweezers, or your fingers, to remove the front camera.
  27. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the microSD card reader: step 27, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the microSD card reader: step 27, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the microSD card reader's press connector secured to the motherboard.
  28. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the rear camera: step 28, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the rear camera: step 28, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the rear camera: step 28, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the rear camera's two press connectors secured to the motherboard.
  29. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the power button cable: step 29, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the power button cable: step 29, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the power button cable's press connector secured to the motherboard.
  30. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the bottom-right coaxial cable: step 30, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the bottom-right coaxial cable: step 30, image 2 of 2
    • Use the point of a spudger to carefully pry up and disconnect the bottom-right loudspeaker's yellow coaxial cable from the motherboard.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  31. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Reposition the bottom-right coaxial cable: step 31, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Reposition the bottom-right coaxial cable: step 31, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Reposition the bottom-right coaxial cable: step 31, image 3 of 3
    • Pull the coaxial cable away from the frame, making sure the cable is completely unthreaded from the motherboard.
  32. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the interconnect cable: step 32, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the interconnect cable: step 32, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable's press connector secured to the motherboard.
  33. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the top-right coaxial cable: step 33, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Disconnect the top-right coaxial cable: step 33, image 2 of 2
    • Use the point of a spudger to carefully pry up and disconnect the top-right loudspeaker's blue coaxial cable from the motherboard.
  34. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Unfasten the motherboard: step 34, image 1 of 2 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Unfasten the motherboard: step 34, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the three 2 mm screws securing the motherboard to the frame.
  35. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the motherboard: step 35, image 1 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the motherboard: step 35, image 2 of 3 Samsung Galaxy Tab S7 Plus Motherboard Replacement, Remove the motherboard: step 35, image 3 of 3
    • Insert a spudger into a gap between the motherboard and the frame.
    • Pry up with the spudger to release the motherboard from its clips.
    • Remove the motherboard.
    • During reassembly, refasten the motherboard screws first to properly align it into place, then reconnect the cables.
  36. Samsung Galaxy Tab S7 Plus Motherboard Replacement, Only the motherboard remains: step 36, image 1 of 1
    • You're now left with the motherboard.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
Alex Diaz-Kokaisl
125,849 Reputation
592 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,529 Guides authored
One Comment
Where can I find a replacement motherboard?
Kevin Montajes - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 48
All Time: 1,492
