Samsung Galaxy Watch4 Battery Replacement
  1. Samsung Galaxy Watch4 Battery Replacement, Power down your Galaxy Watch4: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Battery Replacement, Unscrew the back cover: step 2, image 1 of 1
    • Use a Tri-point Y000 screwdriver to remove the four 4.0 mm-long screws.
  3. Samsung Galaxy Watch4 Battery Replacement, Wedge open the back cover: step 3, image 1 of 2 Samsung Galaxy Watch4 Battery Replacement, Wedge open the back cover: step 3, image 2 of 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch4 Battery Replacement, Disconnect the sensor flex cable: step 4, image 1 of 2 Samsung Galaxy Watch4 Battery Replacement, Disconnect the sensor flex cable: step 4, image 2 of 2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4 Battery Replacement, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Samsung Galaxy Watch4 Battery Replacement, Unscrew the motherboard: step 6, image 1 of 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  7. Samsung Galaxy Watch4 Battery Replacement, Disconnect the display flex cable: step 7, image 1 of 2 Samsung Galaxy Watch4 Battery Replacement, Disconnect the display flex cable: step 7, image 2 of 2
    • Use the flat end of a spudger to disconnect the display flex cable.
  8. Samsung Galaxy Watch4 Battery Replacement, Disconnect the side buttons: step 8, image 1 of 2 Samsung Galaxy Watch4 Battery Replacement, Disconnect the side buttons: step 8, image 2 of 2
    • Use a spudger to disconnect the flex cable of the crown buttons.
  9. Samsung Galaxy Watch4 Battery Replacement, Remove the motherboard: step 9, image 1 of 2 Samsung Galaxy Watch4 Battery Replacement, Remove the motherboard: step 9, image 2 of 2
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
  10. Samsung Galaxy Watch4 Battery Replacement, Lever up the battery: step 10, image 1 of 2 Samsung Galaxy Watch4 Battery Replacement, Lever up the battery: step 10, image 2 of 2
    • Place the tip of an opening pick in the small gap between the plastic frame and the battery, opposite to the display cable.
    • Carefully lever the battery up and out of its recess.
    • Don't try to remove the battery completely yet, as its connector is still adhered to the core assembly.
  11. Samsung Galaxy Watch4 Battery Replacement, Release the battery connector: step 11, image 1 of 2 Samsung Galaxy Watch4 Battery Replacement, Release the battery connector: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Lift the battery up a little in order to access its glued down connector cable.
    • Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
    • You will most likely be able to re-use the adhesive to fix the new battery in place. If not replace it with double sided or pre-cut adhesive tape.
  12. Samsung Galaxy Watch4 Battery Replacement, Remove the battery: step 12, image 1 of 1
    • Remove the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
26 other people completed this guide.
Adriana Zwink
49,401 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
7 Comments
Will this same battery work for the 42mm Galaxy Watch 4 Classic? Or will I need to keep searching for a replacement for that model?
geeowens - Reply
No! The batteries are completely different sizes.
David C -
Guide worked very well for me on the Watch4 (not classic). My battery adhesive came off during the replacement, so it was good to have gotten the adhesive card just in case.
My only note is that the Y000 Tri-point was tool small for the 2nd step. I used the Y00 Tri-point and it worked perfectly. The battery did take some effort to get out. I also used the flat edge of the plastic spudger to help lever up the corner to slide the pick in better.
Chris - Reply
is it still water resistant
Victor Rhebok - Reply
Past 24 Hours: 105
Past 7 Days: 912
Past 30 Days: 3,534
All Time: 49,104
