Samsung Gear S2 Battery Replacement
  1. Samsung Gear S2 Battery Replacement, Watch Strap: step 1, image 1 of 2 Samsung Gear S2 Battery Replacement, Watch Strap: step 1, image 2 of 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Battery Replacement: step 2, image 1 of 2 Samsung Gear S2 Battery Replacement: step 2, image 2 of 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Battery Replacement: step 3, image 1 of 2 Samsung Gear S2 Battery Replacement: step 3, image 2 of 2
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Battery Replacement, Back: step 4, image 1 of 2 Samsung Gear S2 Battery Replacement, Back: step 4, image 2 of 2
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
  5. Samsung Gear S2 Battery Replacement, Motherboard: step 5, image 1 of 2 Samsung Gear S2 Battery Replacement, Motherboard: step 5, image 2 of 2
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
  6. Samsung Gear S2 Battery Replacement: step 6, image 1 of 3 Samsung Gear S2 Battery Replacement: step 6, image 2 of 3 Samsung Gear S2 Battery Replacement: step 6, image 3 of 3
    • Using a spudger, pry up the three cables.
  7. Samsung Gear S2 Battery Replacement: step 7, image 1 of 2 Samsung Gear S2 Battery Replacement: step 7, image 2 of 2
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
  8. Samsung Gear S2 Battery Replacement, Battery: step 8, image 1 of 2 Samsung Gear S2 Battery Replacement, Battery: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, lift the battery casing.
    • Make sure the cables are fed through their gaps to avoid damaging them.
  9. Samsung Gear S2 Battery Replacement: step 9, image 1 of 2 Samsung Gear S2 Battery Replacement: step 9, image 2 of 2
    • Flip the battery casing over and using a spudger, push on the battery to free it from the casing.
    • Once the battery is free, use the flat end of a spudger to lift up the battery cable.
100 other people completed this guide.
Jacob Baldwin
3,412 Reputation
5 Guides authored
USF Tampa, Team S2-G3, Sullivan Spring 2017 Member of USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Members
23 Guides authored
39 Comments
Excellent guidelines, and do you have steps for s3 frontier
pedro tiburcio - Reply
A reference to the battery part number would be great.
Harold Turner - Reply
Very good job and very easy
JEAN PIERRE - Reply
I have the Gear S2 3G version R730V and purchased a battery thinking these instructions would work, but once I opened the watch it is not the same as the one above. Does anyone have instructions on how to replace the batter on the R730V??
Irene - Reply
Past 24 Hours: 4
Past 7 Days: 93
Past 30 Days: 439
All Time: 153,772
