Samsung LNT4669FX-XAA TV Power Supply Board Replacement
    • Be sure to unplug the TV from the main wall outlet.
    • Carefully lay the TV screen down on a clean flat table with the back side facing you.
    • Using a #3 Phillips head screwdriver, remove the screws holding the back cover on.
    • Thoroughly clean the cover and boards using a damp towel (I like to use 91% isopropyl alcohol) and if heavily soiled use a vacuum with a brush.
    • Using the #3 Phillips head screwdriver, remove the screws holding the power supply board on.
    • Unplug the connectors connected to the board setting aside and carefully noting placement for later connection to the new board.
    • Insert the new power supply board into the location where the old board was located.
    • Follow the previous steps to connect the cables and screw in the screws.
    • Follow the first step in reverse to install the back cover.
    • Plug the power cord into a wall outlet and power on the TV to verify performance.
You can also repair your Power Supply Board potentially by using the BN44-00166C repair kit.
See the Attached Documents schematic for further Power Supply Board details.
2 other people completed this guide.
Attached Documents
James Finch
2,298 Reputation
13 Guides authored
One Comment
Power supra wod
Sajeev G - Reply
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 60
All Time: 10,046
