Samsung RF28R7201SG Refrigerator Control Board Replacement
  1. Samsung RF28R7201SG Refrigerator Control Board Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Control Board Replacement, Remove the board access panel: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the five screws securing the board access panel to the back of the refrigerator:
    • Four 14.8 mm-long screws
    • One 12.3 mm-long screw
  3. Samsung RF28R7201SG Refrigerator Control Board Replacement: step 3, image 1 of 2 Samsung RF28R7201SG Refrigerator Control Board Replacement: step 3, image 2 of 2
    • Remove the board access panel.
  4. Samsung RF28R7201SG Refrigerator Control Board Replacement, Reassembly information: step 4, image 1 of 2 Samsung RF28R7201SG Refrigerator Control Board Replacement, Reassembly information: step 4, image 2 of 2
    • The control board has nine wire connectors:
    • Three connectors along the top edge
    • One connector along the right edge
    • One connector along the bottom edge
    • Four connectors along the left edge
    • During reassembly, use the second image to make sure you've reconnected all nine connectors.
  5. Samsung RF28R7201SG Refrigerator Control Board Replacement, Remove the control board: step 5, image 1 of 2 Samsung RF28R7201SG Refrigerator Control Board Replacement, Remove the control board: step 5, image 2 of 2
    • Pull and disconnect each of the nine connectors from the control board.
    • Some connectors may have a locking tab. Squeeze the wide sides of the connector to unlock it, then pull to disconnect it.
    • Move the wires away from the control board so it can slide out of its recess.
  6. Samsung RF28R7201SG Refrigerator Control Board Replacement: step 6, image 1 of 3 Samsung RF28R7201SG Refrigerator Control Board Replacement: step 6, image 2 of 3 Samsung RF28R7201SG Refrigerator Control Board Replacement: step 6, image 3 of 3
    • Use your fingers to push up the plastic lip securing the top edge of the control board to the refrigerator.
    • Swing the control board out and remove it.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
583 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 8
All Time: 103
