Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement
  1. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: step 2, image 1 of 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: step 2, image 2 of 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: step 3, image 1 of 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: step 3, image 2 of 2
    • Remove all the loose shelves and bins from the refrigerator compartment.
    • The bottom shelf is clipped in place. Follow the next step to remove it.
  4. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 4, image 1 of 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 4, image 2 of 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 4, image 3 of 3
    • Two stiff plastic tabs (one on each side) secure the bottom shelf in place.
    • Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
    • If the shelf doesn't unclip, you can try using a flathead screwdriver to press each clip in.
    • Remove the bottom shelf.
  5. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: step 5, image 1 of 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: step 5, image 2 of 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: step 5, image 3 of 3
    • Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
  6. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 6, image 1 of 1
    • Use a Phillips screwdriver to remove the four screws securing the evaporator cover:
    • Two 37 mm-long screws
    • Two 16.5 mm-long screws
  7. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 7, image 1 of 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 7, image 2 of 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 7, image 3 of 3
    • Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
    • Don't try to fully remove the cover in this step, as it's connected by several wires.
  8. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 8, image 1 of 1
    • Squeeze and disconnect the two wire connectors connecting the evaporator cover to the refrigerator.
  9. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 9, image 1 of 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 9, image 2 of 2
    • Pull the evaporator cover towards you and remove it.
  10. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the evaporator fan: step 10, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the four 18.5 mm-long screws securing the fan bracket to the evaporator cover.
  11. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 11, image 1 of 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 11, image 2 of 2
    • Guide the fan cable from the cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  12. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 12, image 1 of 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 12, image 2 of 2
    • Lift the loose edge of the fan bracket up.
  13. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 13, image 1 of 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 13, image 2 of 2
    • The fan is pressure-fit in place with some foam insulation.
    • Use your fingers to press the fan out of its recess.
  14. Samsung RF28R7201SG Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 14, image 1 of 1
    • Remove the fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down, towards the evaporator cover.
Repair didn’t go as planned? Ask our Answers community for help.
2 other people completed this guide.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
34 Members
589 Guides authored
0 Comments
Past 24 Hours: 13
Past 7 Days: 90
Past 30 Days: 371
All Time: 2,725
