Samsung RF28R7201SG Refrigerator Fuse Block Replacement
  1. Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Remove the board access panel: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the five screws securing the board access panel to the back of the refrigerator:
    • Four 14.8 mm-long screws
    • One 12.3 mm-long screw
  3. Samsung RF28R7201SG Refrigerator Fuse Block Replacement: step 3, image 1 of 2 Samsung RF28R7201SG Refrigerator Fuse Block Replacement: step 3, image 2 of 2
    • Remove the board access panel.
  4. Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Remove the fuse block: step 4, image 1 of 3 Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Remove the fuse block: step 4, image 2 of 3 Samsung RF28R7201SG Refrigerator Fuse Block Replacement, Remove the fuse block: step 4, image 3 of 3
    • Squeeze the wide sides of the red connector to unlatch it from the fuse block.
    • Pull to disconnect the connector.
    • Repeat the procedure to disconnect the blue connector.
    • During reassembly, make sure the connectors lock in place. If they don't, you may need to flip their orientation.
  5. Samsung RF28R7201SG Refrigerator Fuse Block Replacement: step 5, image 1 of 3 Samsung RF28R7201SG Refrigerator Fuse Block Replacement: step 5, image 2 of 3 Samsung RF28R7201SG Refrigerator Fuse Block Replacement: step 5, image 3 of 3
    • Use your fingers to pry and release the black plastic clip holding the left edge of the fuse block.
    • Lift out and remove the fuse block.
Repair didn’t go as planned? Ask our Answers community for help.
2 other people completed this guide.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
583 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 11
All Time: 177
