Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement
  1. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Remove the hinge cover: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the three 18.5 mm-long screws securing the hinge cover on the top of the refrigerator.
  3. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: step 3, image 1 of 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: step 4, image 1 of 2 Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: step 4, image 2 of 2
    • Use your fingers to squeeze and disconnect the blue wire connector.
    • Use your fingers to squeeze and disconnect the white wire connector.
  5. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: step 5, image 1 of 1
    • Remove the hinge cover.
  6. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Remove the Wi-Fi card: step 6, image 1 of 3 Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Remove the Wi-Fi card: step 6, image 2 of 3 Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement, Remove the Wi-Fi card: step 6, image 3 of 3
    • The Wi-Fi card is attached to the hinge cover.
    • Use your fingers to squeeze and slide the Wi-Fi cable connector out of its socket.
  7. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: step 7, image 1 of 1
    • Use a Phillips screwdriver to remove the two 9.7 mm-long screws securing the Wi-Fi card to the hinge cover.
  8. Samsung RF28R7201SG Refrigerator Wi-Fi Card Replacement: step 8, image 1 of 1
    • Lift and remove the Wi-Fi card.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
583 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 89
