Sceptre 4K IPS 27" Monitor Button Board Replacement
  1. Sceptre 4K IPS 27" Monitor Button Board Replacement, Button Board: step 1, image 1 of 1
    • Flip the device, and put the back of the screen towards yourself.
    • Use a soft surface to prevent damage to the screen.
  2. Sceptre 4K IPS 27" Monitor Button Board Replacement: step 2, image 1 of 3 Sceptre 4K IPS 27" Monitor Button Board Replacement: step 2, image 2 of 3 Sceptre 4K IPS 27" Monitor Button Board Replacement: step 2, image 3 of 3
    • Remove the seven screws using a Phillips #00 screwdriver.
    • There are four screws on the back panel and three screws on the bottom of the screen.
  3. Sceptre 4K IPS 27" Monitor Button Board Replacement: step 3, image 1 of 2 Sceptre 4K IPS 27" Monitor Button Board Replacement: step 3, image 2 of 2
    • Hook the tip of the screwdriver in the right corner of the back case. Try to pull up the part by your hand while inserting the tip of the screwdriver.
    • Once the tip of the screwdriver is inside the corner, gently slide down the screwdriver to detach the right side of the back case from the screen.
  4. Sceptre 4K IPS 27" Monitor Button Board Replacement: step 4, image 1 of 3 Sceptre 4K IPS 27" Monitor Button Board Replacement: step 4, image 2 of 3 Sceptre 4K IPS 27" Monitor Button Board Replacement: step 4, image 3 of 3
    • Do the same as the previous step with the left corner to detach the left part of the back case from the screen.
    • Open the back case of the screen.
  5. Sceptre 4K IPS 27" Monitor Button Board Replacement: step 5, image 1 of 3 Sceptre 4K IPS 27" Monitor Button Board Replacement: step 5, image 2 of 3 Sceptre 4K IPS 27" Monitor Button Board Replacement: step 5, image 3 of 3
    • In the back of the case you will see the control buttons' board.
    • Disconnect the wire connection by pulling out the wire from the board.
  6. Sceptre 4K IPS 27" Monitor Button Board Replacement: step 6, image 1 of 3 Sceptre 4K IPS 27" Monitor Button Board Replacement: step 6, image 2 of 3 Sceptre 4K IPS 27" Monitor Button Board Replacement: step 6, image 3 of 3
    • Remove the two screws from the board using a Phillips #00 screwdriver.
    • Remove the control button board from the device.
Moeen
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 76
