Sharp-EL-531xg Battery Replacement
  1. Sharp-EL-531xg Battery Replacement, Battery: step 1, image 1 of 1
    • Press the 2nd F button and then the OFF button to power down the calculator.
  2. Sharp-EL-531xg Battery Replacement: step 2, image 1 of 2 Sharp-EL-531xg Battery Replacement: step 2, image 2 of 2
    • Flip the calculator over so the back is facing upwards.
    • Remove the single screw from the battery panel using a Phillips #0 screwdriver.
  3. Sharp-EL-531xg Battery Replacement: step 3, image 1 of 1
    • Remove the battery cover using two fingers.
  4. Sharp-EL-531xg Battery Replacement: step 4, image 1 of 3 Sharp-EL-531xg Battery Replacement: step 4, image 2 of 3 Sharp-EL-531xg Battery Replacement: step 4, image 3 of 3
    • Place a spudger in the slot next to the battery and pry upwards to remove the battery.
    • Avoid using a sharp tool to remove the battery.
  5. Sharp-EL-531xg Battery Replacement: step 5, image 1 of 1
    • Place the new battery into the slot with the positive (+) side facing upwards
    • Don't press the battery too hard.
  6. Sharp-EL-531xg Battery Replacement: step 6, image 1 of 1
    • Put the battery cover back on.
    • Tighten the battery cover screw with a Phillips #0 screwdriver.
  7. Sharp-EL-531xg Battery Replacement: step 7, image 1 of 2 Sharp-EL-531xg Battery Replacement: step 7, image 2 of 2
    • Press the On button to turn on the calculator.
    • Flip the calculator over so the bottom is facing upwards.
    • Press the reset button with the pointed end of a spudger to restart the calculator.
Finish Line
Muhammad Hassan Majeed
166 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 26
All Time: 731
