Softball Glove String Replacement
  1. Softball Glove String Replacement, Softball Glove String: step 1, image 1 of 3 Softball Glove String Replacement, Softball Glove String: step 1, image 2 of 3 Softball Glove String Replacement, Softball Glove String: step 1, image 3 of 3
    • Tie a knot at one end of the string.
  2. Softball Glove String Replacement: step 2, image 1 of 2 Softball Glove String Replacement: step 2, image 2 of 2
    • Put the string through the loop of the leather needle.
  3. Softball Glove String Replacement: step 3, image 1 of 2 Softball Glove String Replacement: step 3, image 2 of 2
    • Push the needle through the first hole on the backside of the pinky finger.
  4. Softball Glove String Replacement: step 4, image 1 of 3 Softball Glove String Replacement: step 4, image 2 of 3 Softball Glove String Replacement: step 4, image 3 of 3
    • Pull the string out of the needle and back the needle out of the hole.
  5. Softball Glove String Replacement: step 5, image 1 of 2 Softball Glove String Replacement: step 5, image 2 of 2
    • Pull the string all the way through and reinsert the string into the needle.
  6. Softball Glove String Replacement: step 6, image 1 of 2 Softball Glove String Replacement: step 6, image 2 of 2
    • Push the needle through the bottom hole on the ring finger.
    • Pull the string out of the needle and all the way through the hole. Back the needle out of the hole.
  7. Softball Glove String Replacement: step 7, image 1 of 3 Softball Glove String Replacement: step 7, image 2 of 3 Softball Glove String Replacement: step 7, image 3 of 3
    • Insert the string back into the needle and push it through the bottom hole on the pinky.
    • Pull the string all the way through and remove it from the needle.
  8. Softball Glove String Replacement: step 8, image 1 of 3 Softball Glove String Replacement: step 8, image 2 of 3 Softball Glove String Replacement: step 8, image 3 of 3
    • Pull the string under the loop, making an X.
  9. Softball Glove String Replacement: step 9, image 1 of 3 Softball Glove String Replacement: step 9, image 2 of 3 Softball Glove String Replacement: step 9, image 3 of 3
    • Put the string through the needle and push the needle though the top hole on the ring finger.
  10. Softball Glove String Replacement: step 10, image 1 of 3 Softball Glove String Replacement: step 10, image 2 of 3 Softball Glove String Replacement: step 10, image 3 of 3
    • Going around the back of the ring finger, insert the string through the top hole on the left side of the ring finger.
    • Pull the string all the way through.
  11. Softball Glove String Replacement: step 11, image 1 of 3 Softball Glove String Replacement: step 11, image 2 of 3 Softball Glove String Replacement: step 11, image 3 of 3
    • Insert the string through the bottom hole on the middle finger.
  12. Softball Glove String Replacement: step 12, image 1 of 2 Softball Glove String Replacement: step 12, image 2 of 2
    • Cross over the backside and insert the string into the bottom hole on the left side of the ring finger.
  13. Softball Glove String Replacement: step 13, image 1 of 3 Softball Glove String Replacement: step 13, image 2 of 3 Softball Glove String Replacement: step 13, image 3 of 3
    • Pull the string under the loop to make an X.
  14. Softball Glove String Replacement: step 14, image 1 of 3 Softball Glove String Replacement: step 14, image 2 of 3 Softball Glove String Replacement: step 14, image 3 of 3
    • Push the string through the top hole on the right side of the middle finger.
  15. Softball Glove String Replacement: step 15, image 1 of 3 Softball Glove String Replacement: step 15, image 2 of 3 Softball Glove String Replacement: step 15, image 3 of 3
    • Going around the back of the middle finger, insert the string into top hole on the right side of the middle finger.
  16. Softball Glove String Replacement: step 16, image 1 of 3 Softball Glove String Replacement: step 16, image 2 of 3 Softball Glove String Replacement: step 16, image 3 of 3
    • Insert the string into the bottom right hole on the pointer finger.
  17. Softball Glove String Replacement: step 17, image 1 of 3 Softball Glove String Replacement: step 17, image 2 of 3 Softball Glove String Replacement: step 17, image 3 of 3
    • On the backside, push the string through the bottom left hole on the middle finger and pull the string all the way through.
  18. Softball Glove String Replacement: step 18, image 1 of 3 Softball Glove String Replacement: step 18, image 2 of 3 Softball Glove String Replacement: step 18, image 3 of 3
  19. Softball Glove String Replacement: step 19, image 1 of 3 Softball Glove String Replacement: step 19, image 2 of 3 Softball Glove String Replacement: step 19, image 3 of 3
    • Insert the string into the top right hole on the pointer finger and pull the string all the way through.
  20. Softball Glove String Replacement: step 20, image 1 of 3 Softball Glove String Replacement: step 20, image 2 of 3 Softball Glove String Replacement: step 20, image 3 of 3
    • Tie the end of the string close to the glove.
    • Cut off the excess string.
To remove a string from a softball glove, repeat these steps in reverse order.
Christina Hart
331 Reputation
1 Guide authored
One Comment
Thank you so much for sharing this guide on softball glove string replacement! Your step-by-step instructions made it easy for me to replace the strings on my old glove and bring it back to life. Your expertise and generosity are truly appreciated!
Juliet Cyrus - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 913
