Sony Vaio Tap 11 Power Jack Replacement
  1. Sony Vaio Tap 11 Power Jack Replacement, Screen Assembly: step 1, image 1 of 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Power Jack Replacement: step 2, image 1 of 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Power Jack Replacement: step 3, image 1 of 2 Sony Vaio Tap 11 Power Jack Replacement: step 3, image 2 of 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Power Jack Replacement, Battery: step 4, image 1 of 1
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Power Jack Replacement: step 5, image 1 of 1
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Power Jack Replacement, Power Jack: step 6, image 1 of 1
    • Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
  7. Sony Vaio Tap 11 Power Jack Replacement: step 7, image 1 of 1
    • Unplug the jack from the motherboard.
  8. Sony Vaio Tap 11 Power Jack Replacement: step 8, image 1 of 1
    • Remove the metal covering.
  9. Sony Vaio Tap 11 Power Jack Replacement: step 9, image 1 of 1
    • Pull out the cable and jack assembly.
3 other people completed this guide.
Alexander Bridges
1,217 Reputation
7 Guides authored
IUPUI, Team 1-2, Harley Fall 2015 Member of IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Members
20 Guides authored
2 Comments
I wonder if you have the part number or can supply this power jack?
James Toal - Reply
Yes, Where can I find this replacement part?
mikebeard65 - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 1,789
