Sony Vaio Tap 11 Solid State Disk Replacement
  1. Sony Vaio Tap 11 Solid State Disk Replacement, Screen Assembly: step 1, image 1 of 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Solid State Disk Replacement: step 2, image 1 of 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Solid State Disk Replacement: step 3, image 1 of 2 Sony Vaio Tap 11 Solid State Disk Replacement: step 3, image 2 of 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Solid State Disk Replacement, Solid State Disk: step 4, image 1 of 1
    • Unplug the battery connector located beside the fan.
    • Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
  5. Sony Vaio Tap 11 Solid State Disk Replacement: step 5, image 1 of 1
    • Remove the two 3 mm Phillips #000 screws from the right edge of the SSD.
  6. Sony Vaio Tap 11 Solid State Disk Replacement: step 6, image 1 of 2 Sony Vaio Tap 11 Solid State Disk Replacement: step 6, image 2 of 2
    • Pull the SSD towards the right and slightly up, removing it from the back assembly.
3 other people completed this guide.
Alexander Bridges
1,217 Reputation
7 Guides authored
IUPUI, Team 1-2, Harley Fall 2015 Member of IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Members
20 Guides authored
3 Comments
What kind of M2 Type? SSD is needed for replacement/upgrade?
Marius - Reply
OK, found the answer, it's mSATA, like the Samsung 840 EVO Series:
http://www.samsung.com/us/business/suppo...
Marius -
I did the same without pulling out the battery jack. As i tried to turn the tablet on it didn’t work. Even the fan stopped working. I inserted the power cable but no response .. nothing at all ! Please help!
ib_1990_ib - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 6,016
