Sony XPERIA Tablet Z Motherboard Replacement
  1. Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: step 1, image 1 of 3 Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: step 1, image 2 of 3 Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Remove the back cover by using the plastic opening tools.
  2. Sony XPERIA Tablet Z Motherboard Replacement: step 2, image 1 of 2 Sony XPERIA Tablet Z Motherboard Replacement: step 2, image 2 of 2
    • Disconnect the battery by lifting the connector straight up from the motherboard with a plastic opening tool or equivalent.
    • Do not pry on the wires. Only pry up on the white plastic part of the connector that is closest to the battery itself.
  3. Sony XPERIA Tablet Z Motherboard Replacement: step 3, image 1 of 2 Sony XPERIA Tablet Z Motherboard Replacement: step 3, image 2 of 2
    • Pry up the tape and ribbon cable connector for front facing camera.
    • Remove front facing camera and cables.
  4. Sony XPERIA Tablet Z Motherboard Replacement: step 4, image 1 of 1
    • Slide the ribbon cable out of motherboard.
    • This cable is the only one in this guide that slides out from the motherboard in a motion that is parallel to the motherboard.
  5. Sony XPERIA Tablet Z Motherboard Replacement: step 5, image 1 of 3 Sony XPERIA Tablet Z Motherboard Replacement: step 5, image 2 of 3 Sony XPERIA Tablet Z Motherboard Replacement: step 5, image 3 of 3
    • Use a Phillips head #0 screwdriver to remove the 3.06 mm screws from the Micro USB retaining plate.
    • Remove the cover plates.
    • There is plastic plate and a metal one.
    • Remove the USB port partially from its position. It can stay connected just moved out of the way.
  6. Sony XPERIA Tablet Z Motherboard Replacement: step 6, image 1 of 2 Sony XPERIA Tablet Z Motherboard Replacement: step 6, image 2 of 2
    • Use a Phillips head #0 screw driver to remove the 3.43 mm screws on the volume control retaining plate.
    • Remove the volume control.
  7. Sony XPERIA Tablet Z Motherboard Replacement: step 7, image 1 of 1
    • Lift up the connector for the rear facing camera.
    • Remove the rear facing camera.
  8. Sony XPERIA Tablet Z Motherboard Replacement: step 8, image 1 of 2 Sony XPERIA Tablet Z Motherboard Replacement: step 8, image 2 of 2
    • Use a Phillips head #0 screwdriver to remove the 3.43mm cover plate screws for headphone port, power button, and status LED assembly.
    • Remove headphone port, power button, and status LED assembly cover plate.
  9. Sony XPERIA Tablet Z Motherboard Replacement: step 9, image 1 of 2 Sony XPERIA Tablet Z Motherboard Replacement: step 9, image 2 of 2
    • Disconnect the connectors for the headphone port, power button, LED from the mother board.
    • Remove the headphone port, power button, and LED from the mother board.
  10. Sony XPERIA Tablet Z Motherboard Replacement: step 10, image 1 of 3 Sony XPERIA Tablet Z Motherboard Replacement: step 10, image 2 of 3 Sony XPERIA Tablet Z Motherboard Replacement: step 10, image 3 of 3
    • Disconnect the 3 ribbon cable connectors from the mother board near the USB port and speaker.
  11. Sony XPERIA Tablet Z Motherboard Replacement: step 11, image 1 of 1
    • Remove the motherboard by gently prying up. Once it is loosened from the adhesive you may need to slide it away from the battery while lifting.
3 other people completed this guide.
Jasminh Schelkopf
261 Reputation
2 Guides authored
IUPUI, Team S5-G1, Harley Summer 2017 Member of IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 29
All Time: 2,208
