Surface Laptop Studio Lower Case Replacement
  1. Surface Laptop Studio Lower Case Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Lower Case Replacement: step 2, image 1 of 2 Surface Laptop Studio Lower Case Replacement: step 2, image 2 of 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Lower Case Replacement: step 3, image 1 of 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Lower Case Replacement: step 4, image 1 of 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Lower Case Replacement: step 5, image 1 of 2 Surface Laptop Studio Lower Case Replacement: step 5, image 2 of 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
Connor Bassolino
6,694 Reputation
28 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 110
All Time: 1,324
