TRS-80 Color Computer Fuse Replacement
Christopher Paige
Christopher Paige and 4 other contributors
Last updated on April 28, 2022
20 - 40 minutes
Difficult
Introduction
Go to step 1
Replace a broken fuse on the TRS-80 Color Computer's power supply.
Tools
Show more…
  1. TRS-80 Color Computer Fuse Replacement, Outside Casing: step 1, image 1 of 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Fuse Replacement: step 2, image 1 of 2 TRS-80 Color Computer Fuse Replacement: step 2, image 2 of 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Fuse Replacement, Keyboard: step 3, image 1 of 2 TRS-80 Color Computer Fuse Replacement, Keyboard: step 3, image 2 of 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Fuse Replacement, Motherboard: step 4, image 1 of 3 TRS-80 Color Computer Fuse Replacement, Motherboard: step 4, image 2 of 3 TRS-80 Color Computer Fuse Replacement, Motherboard: step 4, image 3 of 3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Fuse Replacement: step 5, image 1 of 3 TRS-80 Color Computer Fuse Replacement: step 5, image 2 of 3 TRS-80 Color Computer Fuse Replacement: step 5, image 3 of 3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Fuse Replacement, Fuse: step 6, image 1 of 2 TRS-80 Color Computer Fuse Replacement, Fuse: step 6, image 2 of 2
    • Remove the two 40.6mm Philips screws securing the TRS-80 transformer.
  7. TRS-80 Color Computer Fuse Replacement: step 7, image 1 of 3 TRS-80 Color Computer Fuse Replacement: step 7, image 2 of 3 TRS-80 Color Computer Fuse Replacement: step 7, image 3 of 3
    • Remove the power cable jumpers from the power supply.
  8. TRS-80 Color Computer Fuse Replacement: step 8, image 1 of 1
    • Gently peel back the protective film on the top of the transformer.
  9. TRS-80 Color Computer Fuse Replacement: step 9, image 1 of 3 TRS-80 Color Computer Fuse Replacement: step 9, image 2 of 3 TRS-80 Color Computer Fuse Replacement: step 9, image 3 of 3
    • Locate the two points the fuse is soldered into the circuit board.
    • Using a soldering iron and soldering wick, desolder and remove the fuse.
    • Place the new fuse into the location of the old one, and solder it in place.
3 other people completed this guide.
Christopher Paige
549 Reputation
3 Guides authored
Cal Poly, Team 11-24, Maness Winter 2011 Member of Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 16
All Time: 2,924
