TiVo Series 2 TCD24008A Hard Drive Replacement
  1. TiVo Series 2 TCD24008A Hard Drive Replacement, Cover: step 1, image 1 of 1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Hard Drive Replacement: step 2, image 1 of 1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Hard Drive Replacement: step 3, image 1 of 1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Locate the hard drive.
  5. TiVo Series 2 TCD24008A Hard Drive Replacement: step 5, image 1 of 2 TiVo Series 2 TCD24008A Hard Drive Replacement: step 5, image 2 of 2
    • Remove the ribbon cable by applying firm pressure to the black tabs on the sides.
    • Remove the power cable to the right of the ribbon cable.
  6. TiVo Series 2 TCD24008A Hard Drive Replacement: step 6, image 1 of 3 TiVo Series 2 TCD24008A Hard Drive Replacement: step 6, image 2 of 3 TiVo Series 2 TCD24008A Hard Drive Replacement: step 6, image 3 of 3
    • Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove.
Talha
31 Reputation
2 Guides authored
Cal Poly, Team 5-33, Amido Fall 2011 Member of Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,747
