Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement
  1. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement, Back Cover: step 1, image 1 of 2 Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: step 2, image 1 of 2 Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: step 2, image 2 of 2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: step 3, image 1 of 1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: step 4, image 1 of 2 Toshiba CB35-C3300 Chromebook 2 Back Cover Replacement: step 4, image 2 of 2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
Jillian Thomas
209 Reputation
4 Guides authored
USF Tampa, Team S1-G121, Cagle Fall 2017 Member of USF Tampa, Team S1-G121, Cagle Fall 2017
USFT-CAGLE-F17S1G121
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 389
