Toshiba Chromebook 2 Battery Replacement
  1. Toshiba Chromebook 2 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Battery Replacement: step 2, image 1 of 1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Battery Replacement: step 3, image 1 of 2 Toshiba Chromebook 2 Battery Replacement: step 3, image 2 of 2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Battery Replacement: step 4, image 1 of 2 Toshiba Chromebook 2 Battery Replacement: step 4, image 2 of 2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Battery Replacement: step 5, image 1 of 1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Battery Replacement, Battery: step 6, image 1 of 2 Toshiba Chromebook 2 Battery Replacement, Battery: step 6, image 2 of 2
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Battery Replacement: step 7, image 1 of 2 Toshiba Chromebook 2 Battery Replacement: step 7, image 2 of 2
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Battery Replacement: step 8, image 1 of 1
    • Remove the battery by gently pulling up on the bottom corners.
50 other people completed this guide.
Foster Chaney
762 Reputation
1 Guide authored
IUPUI, Team 1-3, Hagerty Fall 2015 Member of IUPUI, Team 1-3, Hagerty Fall 2015
IUPUI-HAGERTY-F15S1G3
5 Members
7 Guides authored
7 Comments
does the cb30-b-103 battery also work with the cb30-b-104 series?
henrikahlberg94 - Reply
I had four screws holding down battery.
When re-installing cover, don’t get confused. There are two holes under rubber feet on side CLOSEST TO HINGES. These do not accept the two screws - put them on side AWAY FROM HINGES.
Bill Brasier - Reply
Good instructions, my chrome is back to normal again .
Alexander Slaven - Reply
Many thanks but now there’s no curser! What do I do?
Chris in UK
Chris Tighe - Reply
Thank you, easy to follow, works like a dream
steve smith - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 28,756
