Valve Index Base Station IR Laser Replacement
  1. Valve Index Base Station IR Laser Replacement, Opening Base Station: step 1, image 1 of 2 Valve Index Base Station IR Laser Replacement, Opening Base Station: step 1, image 2 of 2
    • Score the front plastic.
    • Use the soldering iron to cut part of it until you can open it with pliers.
  2. Valve Index Base Station IR Laser Replacement, Remove Plastic Guard: step 2, image 1 of 2 Valve Index Base Station IR Laser Replacement, Remove Plastic Guard: step 2, image 2 of 2
    • The top piece has a slop ramp and it is hard to get off.
  3. Valve Index Base Station IR Laser Replacement, Remove Main Unit: step 3, image 1 of 1
    • Use a T8 screwdriver to remove the four screws that are marked with a blue circle.
  4. Valve Index Base Station IR Laser Replacement, Take off Diode Laser Control Board: step 4, image 1 of 1
    • It is contact pins.
    • Use a T8 screwdriver.
  5. Valve Index Base Station IR Laser Replacement, Pull Out IR Laser Diode: step 5, image 1 of 1
    • Use needle-nose pliers to pry out the piece marked by the blue circle.
  6. Valve Index Base Station IR Laser Replacement, Insert 1.0 IR led: step 6, image 1 of 1
    • Line up the flat sides.
    • Then add hot glue around the diode case.
  7. Valve Index Base Station IR Laser Replacement, Strip Wires: step 7, image 1 of 1
    • Very small wires.
  8. Valve Index Base Station IR Laser Replacement, Solder IR Laser to IR Controller Board: step 8, image 1 of 1
    • Black PL1
    • Red PL2
    • White PL3
  9. Valve Index Base Station IR Laser Replacement, Reassemble Unit: Follow steps in reverse: step 9, image 1 of 3 Valve Index Base Station IR Laser Replacement, Reassemble Unit: Follow steps in reverse: step 9, image 2 of 3 Valve Index Base Station IR Laser Replacement, Reassemble Unit: Follow steps in reverse: step 9, image 3 of 3
    • Follow start steps in reverse.
3 other people completed this guide.
Omegakitty
211 Reputation
1 Guide authored
8 Comments
Can you use HLD830030N5T, 5,6mm TO18 30mW 830nm Laser diodes as replacement or is the wattage different?
Thank you for the Info that the 1.0 Laser works in the 2.0 Variant!
Johannes Steinchen - Reply
TLDR, no you need 200mw to replace it.
The wattage for a base station laser is 200mW 830nm. With a 30mW I would expect the laser to immediately burn out because of constant current output.
Omegakitty -
Thank you very much!
by any chance could you send a link to that exact laser please and thank you
xen isy - Reply
Past 24 Hours: 11
Past 7 Days: 46
Past 30 Days: 256
All Time: 1,446
