Vankyo Projector Leisure 3 Polarized Lens Glass Replacement
  1. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement, Polarized Lens Glass: step 1, image 1 of 1
    • Disconnect the projector from any power source and allow it to cool down before starting the repair.
  2. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 2, image 1 of 3 Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 2, image 2 of 3 Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 2, image 3 of 3
    • Place the projector upside down.
    • Use a Phillips #00 screwdriver to remove the five 1.5mm screws from the base of the projector.
    • Remove the base of the project.
    • There is a cable attached to the motherboard and the bottom case of the projector so don't yank or pull it off.
  3. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 3, image 1 of 3 Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 3, image 2 of 3 Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to remove four 1.0 mm screws from the black cover.
    • Slowly lift the black triangular shaped cover and gently place it aside.
  4. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 4, image 1 of 3 Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 4, image 2 of 3 Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 4, image 3 of 3
    • Carefully remove the old polarized glass lens by lifting it up and out of the slot.
    • Take extra care while working with the polarized lens glass to avoid breaking it and damaging the projector or getting cut.
  5. Vankyo Projector Leisure 3 Polarized Lens Glass Replacement: step 5, image 1 of 1
    • Gently replace the new polarized glass.
Congratulations! You have successfully completed the replacement of the polarized lens glass in your Vankyo Projector Leisure 3. By following this guide, you have taken a crucial step towards restoring optimal image quality and ensuring a satisfying viewing experience.
Remember, the polarized lens glass plays a vital role in filtering light and enhancing the projected images. By addressing issues such as blurry or distorted images, you have effectively resolved common problems associated with a damaged or worn-out lens.
We hope this guide has empowered you to take charge of the repair process and provided valuable insights into the inner workings of your projector. Remember to handle the polarized lens glass with care.
Now that you have successfully completed this repair, you can enjoy your Vankyo Projector Leisure 3 with renewed clarity and vibrancy in its projections. Should you encounter any future issues or require additional repairs, don't hesitate to consult further resources or reach out for assistance.
Thank you for using this guide, and we wish you many enjoyable movie nights and presentations with your Vankyo Projector Leisure 3!
Meetika Kanumukula
121 Reputation
1 Guide authored
2 Comments
Thank you for the guide! Where do we get a replacement polarized glass lens from?
Jenna Lee - Reply
Hello! I found a replacement on eBay, I haven't received it yet, but I saw this comment before hunting for one online! I would've waited until I received it to be sure it's good, but I know I'll most certainly forget, plus the seller has pretty solid reviews.
https://www.ebay.com/itm/115448154872
V Villa -
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 107
All Time: 1,317
