Whirlpool Refrigerator Control Board Replacement
  1. Whirlpool Refrigerator Control Board Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: step 2, image 1 of 2 Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: step 2, image 2 of 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: step 3, image 1 of 3 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: step 3, image 2 of 3 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: step 3, image 3 of 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Control Board Replacement, Unfasten the control board: step 4, image 1 of 1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Control Board Replacement: step 5, image 1 of 3 Whirlpool Refrigerator Control Board Replacement: step 5, image 2 of 3 Whirlpool Refrigerator Control Board Replacement: step 5, image 3 of 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: step 6, image 1 of 3 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: step 6, image 2 of 3 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: step 6, image 3 of 3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Control Board Replacement, Remove the control board: step 7, image 1 of 1
    • Remove the control board.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
574 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 148
All Time: 1,564
