Whirlpool Refrigerator Freezer Door Replacement
  1. Whirlpool Refrigerator Freezer Door Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Door Replacement, Open the doors: step 2, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: step 2, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: step 3, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: step 3, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: step 3, image 3 of 3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: step 4, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: step 4, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: step 4, image 3 of 3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: step 5, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: step 5, image 2 of 2
    • Remove the screw(s) securing the freezer door wiring harness.
    • Remove the screw(s) securing the freezer door water hose.
  6. Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: step 6, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: step 6, image 2 of 2
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: step 7, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: step 7, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: step 7, image 3 of 3
    • Disconnect any connectors attached to the door wiring harness.
  8. Whirlpool Refrigerator Freezer Door Replacement: step 8, image 1 of 1
    • Place a clean cloth under the water hose before continuing.
  9. Whirlpool Refrigerator Freezer Door Replacement: step 9, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement: step 9, image 2 of 2
    • Pull the plastic clip off the freezer door water hose.
  10. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: step 10, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: step 10, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: step 10, image 3 of 3
    • Use one hand to compress the blue plastic ring into the green section of the hose.
    • Use the other hand to pull the water tube out of its slot.
  11. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: step 11, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: step 11, image 2 of 2
    • Depending on your device, you may have a plastic cover on the hinge. Remove it before continuing.
    • Hold the door while performing the next two steps to avoid the door from accidentally falling.
    • Remove the screw(s) securing the freezer door.
    • Some devices may have screws solely for alignment. You don't need to remove these.
  12. Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: step 12, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: step 12, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: step 12, image 3 of 3
    • Pull the door hinge straight up to separate its alignment pins from the chassis.
    • Remove the door hinge.
  13. Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: step 13, image 1 of 3 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: step 13, image 2 of 3 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: step 13, image 3 of 3
    • Pull the freezer door straight up to disconnect it from the chassis.
    • Thread the cables through their slot in the chassis.
    • You may need to thread them individually.
  14. Whirlpool Refrigerator Freezer Door Replacement, Remove the door: step 14, image 1 of 2 Whirlpool Refrigerator Freezer Door Replacement, Remove the door: step 14, image 2 of 2
    • You're now left with the freezer door.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
574 Guides authored
One Comment
There is a pending class action suit about this defect: https://chimicles.com/whirlpool-refriger...
Barbara Hoover - Reply
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 70
All Time: 1,262
