Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement
  1. Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply (if connected)
    • Unplug your device
  2. Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Unfasten the condenser cover: step 2, image 1 of 1
    • Use a nut driver to remove the screws from the condenser cover
  3. Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Remove the condenser cover: step 3, image 1 of 3 Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Remove the condenser cover: step 3, image 2 of 3 Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Remove the condenser cover: step 3, image 3 of 3
    • Lift the bottom edge of the condenser cover away from the refrigerator.
    • Pull down on the condenser cover to free it from the retaining tabs at the top edge and remove it.
  4. Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Remove the thermal protector and start relay: step 4, image 1 of 1
    • Cut any cable ties securing the thermal protector and start relay to the compressor.
    • This device may alternatively be secured by a metal bail or spring clamp. If so, unhook it from one of the holes where it is secured and remove it.
  5. Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Disconnect the ground wire: step 5, image 1 of 2 Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Disconnect the ground wire: step 5, image 2 of 2
    • Use long nose pliers to pull and disconnect the ground wire from the compressor.
  6. Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Remove the assembly: step 6, image 1 of 2 Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Remove the assembly: step 6, image 2 of 2
    • Pull the thermal protector and start relay assembly straight off the compressor to disconnect it.
  7. Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Disconnect the wires: step 7, image 1 of 3 Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Disconnect the wires: step 7, image 2 of 3 Whirlpool Refrigerator Motor Thermal Protector and Start Relay Assembly Replacement, Disconnect the wires: step 7, image 3 of 3
    • Note the positions of the wires connected to the assembly.
    • Pull straight back on the spade connectors with long nose pliers to disconnect the wires.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
30,288 Reputation
213 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,494 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 106
