Whirlpool Refrigerator Start Relay Assembly Replacement
  1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: step 2, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: step 2, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: step 2, image 3 of 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: step 3, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: step 3, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: step 3, image 3 of 3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: step 4, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: step 4, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: step 4, image 3 of 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
  5. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: step 5, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: step 5, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: step 5, image 3 of 3
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
  6. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: step 6, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: step 6, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: step 6, image 3 of 3
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the start capacitor, start relay, and overload relay.
  7. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: step 7, image 1 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: step 7, image 2 of 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: step 7, image 3 of 3
    • If you own a multimeter, you can test the start relay and overload relay's resistance.
    • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
Repair didn’t go as planned? Ask our Answers community for help.
4 other people completed this guide.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
574 Guides authored
2 Comments
Is it universal part
dyannatorres@yahoo.com - Reply
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO -
Past 24 Hours: 14
Past 7 Days: 77
Past 30 Days: 392
All Time: 8,068
