Whirlpool Refrigerator Thermistor Replacement
  1. Whirlpool Refrigerator Thermistor Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Thermistor Replacement, Open the doors: step 2, image 1 of 3 Whirlpool Refrigerator Thermistor Replacement, Open the doors: step 2, image 2 of 3 Whirlpool Refrigerator Thermistor Replacement, Open the doors: step 2, image 3 of 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: step 3, image 1 of 2 Whirlpool Refrigerator Thermistor Replacement, Unfasten the temperature control board assembly: step 3, image 2 of 2
    • Remove the screw(s) securing the temperature control board assembly.
    • The second photo shows the potential screw locations in a removed assembly.
  4. Whirlpool Refrigerator Thermistor Replacement, Reposition the assembly: step 4, image 1 of 3 Whirlpool Refrigerator Thermistor Replacement, Reposition the assembly: step 4, image 2 of 3 Whirlpool Refrigerator Thermistor Replacement, Reposition the assembly: step 4, image 3 of 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. Whirlpool Refrigerator Thermistor Replacement, Disconnect the temperature control board: step 5, image 1 of 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the temperature control board: step 5, image 2 of 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the temperature control board: step 5, image 3 of 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the temperature control board assembly.
  6. Whirlpool Refrigerator Thermistor Replacement, Remove the assembly: step 6, image 1 of 1
    • Remove the temperature control board assembly.
  7. Whirlpool Refrigerator Thermistor Replacement, Disconnect the thermistor: step 7, image 1 of 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the thermistor: step 7, image 2 of 3 Whirlpool Refrigerator Thermistor Replacement, Disconnect the thermistor: step 7, image 3 of 3
    • Disconnect any connectors attached to the thermistor.
  8. Whirlpool Refrigerator Thermistor Replacement, Remove the thermistor: step 8, image 1 of 2 Whirlpool Refrigerator Thermistor Replacement, Remove the thermistor: step 8, image 2 of 2
    • Use a flathead screwdriver, or a similar tool, to pry up the thermistor from its slot in the chassis.
    • Remove the thermistor.
  9. Whirlpool Refrigerator Thermistor Replacement, Meter the thermistor: step 9, image 1 of 1
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
574 Guides authored
3 Comments
Great article. I have a question: My Kenmore refrigerator stopped cooling. I noticed that the compressor and fan were not operating but the evap fan was. I get no power to the compressor or fan. I replaced the start capacitor and start relay with a 3 in 1 start capacitor. Still nothing. I decided to wire the new 3 in 1 and fan with a separate AC wire directly to an outlet. This allowed the fan to start and the compressor started to cool the refrigerator. But obviously I can't use the refrig that way. Would a faulty thermistor prohibit AC from reaching the compressor and fan? I'm hoping it's not the control board. Any suggestions would be greatly appreciated. Barry
reggaemoose - Reply
Great question! I'm going to call in @billg66 (Bill G) as iFixit's appliance pro. If you're able to share your make/model, or find a circuit schematic, your questions about the electrical pathway could be more easily solved. Good luck.
nicO -
Hi Barry, your model number would be a huge help as then I can get service manuals. I'd be cautious about using a 3 in 1. Especially if your fridge was designed to use just a start relay. I think there could be an issue with the thermistor, or possibly the control board, given that the compressor ran when jumped. 3 in 1s are great to squeeze out a little more life from a compressor, but this may not be that case.
Bill Gilbert -
Past 24 Hours: 6
Past 7 Days: 61
Past 30 Days: 240
All Time: 3,020
