Wii U GamePad LCD Display Replacement
Video Overview
  1. Wii U GamePad LCD Display Replacement, Battery: step 1, image 1 of 1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad LCD Display Replacement: step 2, image 1 of 1
    • Lift and remove the battery plate.
  3. Wii U GamePad LCD Display Replacement: step 3, image 1 of 3 Wii U GamePad LCD Display Replacement: step 3, image 2 of 3 Wii U GamePad LCD Display Replacement: step 3, image 3 of 3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad LCD Display Replacement, Outer Case: step 4, image 1 of 3 Wii U GamePad LCD Display Replacement, Outer Case: step 4, image 2 of 3 Wii U GamePad LCD Display Replacement, Outer Case: step 4, image 3 of 3
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad LCD Display Replacement: step 5, image 1 of 1
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Do not pull on the wires as shown in this picture, they will likely break off. Pull directly on the plug (NOT the receptacle)
  6. Wii U GamePad LCD Display Replacement, Speakers: step 6, image 1 of 2 Wii U GamePad LCD Display Replacement, Speakers: step 6, image 2 of 2
    • With your fingers, unplug the left speaker cable from the motherboard.
  7. Wii U GamePad LCD Display Replacement: step 7, image 1 of 2 Wii U GamePad LCD Display Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
  8. Wii U GamePad LCD Display Replacement, WiFi: step 8, image 1 of 3 Wii U GamePad LCD Display Replacement, WiFi: step 8, image 2 of 3 Wii U GamePad LCD Display Replacement, WiFi: step 8, image 3 of 3
    Buy
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
  9. Wii U GamePad LCD Display Replacement: step 9, image 1 of 2 Wii U GamePad LCD Display Replacement: step 9, image 2 of 2
    • With your fingers, lift and remove WiFi board.
    • Remove the board carefully as there are still two wires attached.
  10. Wii U GamePad LCD Display Replacement: step 10, image 1 of 2 Wii U GamePad LCD Display Replacement: step 10, image 2 of 2
    • Disconnect the black and white wires off of the back of the WiFi module.
  11. Wii U GamePad LCD Display Replacement: step 11, image 1 of 1
    • Lift and remove the WiFi module.
  12. Wii U GamePad LCD Display Replacement, Motherboard: step 12, image 1 of 1
    Buy
    • Disconnect the analog connector with tweezers.
  13. Wii U GamePad LCD Display Replacement: step 13, image 1 of 2 Wii U GamePad LCD Display Replacement: step 13, image 2 of 2
    • Remove the blue connector using tweezers.
  14. Wii U GamePad LCD Display Replacement: step 14, image 1 of 2 Wii U GamePad LCD Display Replacement: step 14, image 2 of 2
    • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
    • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon. Be careful, the clasp breaks easily.
  15. Wii U GamePad LCD Display Replacement: step 15, image 1 of 1
    • Remove the small orange ribbon with the tweezers.
  16. Wii U GamePad LCD Display Replacement: step 16, image 1 of 3 Wii U GamePad LCD Display Replacement: step 16, image 2 of 3 Wii U GamePad LCD Display Replacement: step 16, image 3 of 3
    • Remove these two connectors to the motherboard with your fingers.
  17. Wii U GamePad LCD Display Replacement: step 17, image 1 of 2 Wii U GamePad LCD Display Replacement: step 17, image 2 of 2
    • Remove the NFC communicator.
    • When removing the NFC communicator, be careful with the small connector on the back side.
    • Remove the small connector plug-in on the back.
  18. Wii U GamePad LCD Display Replacement: step 18, image 1 of 3 Wii U GamePad LCD Display Replacement: step 18, image 2 of 3 Wii U GamePad LCD Display Replacement: step 18, image 3 of 3
    • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
    • Lift and remove the mother board.
  19. Wii U GamePad LCD Display Replacement, LCD Display: step 19, image 1 of 2 Wii U GamePad LCD Display Replacement, LCD Display: step 19, image 2 of 2
    • Remove the four 5.1mm screws using Phillips size #0 screwdriver.
    • Pull the white and black cables away from the display case.
  20. Wii U GamePad LCD Display Replacement: step 20, image 1 of 2 Wii U GamePad LCD Display Replacement: step 20, image 2 of 2
    • Lift and remove the grey display case with your fingers.
  21. Wii U GamePad LCD Display Replacement: step 21, image 1 of 2 Wii U GamePad LCD Display Replacement: step 21, image 2 of 2
    • Gently with your fingers, press on the front of the display and it will lift up.
    • Remove the display with your fingers.
79 other people completed this guide.
Valentina Cerruty
3,369 Reputation
7 Guides authored
USF Tampa, Team 1-6, Sullivan Spring 2016 Member of USF Tampa, Team 1-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G6
4 Members
40 Guides authored
18 Comments
was really perfect to repair my device. Thank you very much for this help
Bernd Dietrich - Reply
In step 14 - what does the small gray ribbon do? The replacement LCD display that I got in the mail did not have it.
Stacey Hoggard - Reply
Its the touch screen cable. The screen I ordered did not come with one. I had to carefully remove it from my broken display and put it on the new one. Thankfully the touchscreen still works for me.
Terry Moenkhaus -
Very happy with your manual! I've fixed it.
Paulus 68 - Reply
Mine did not come with the touch screen either.
Edwin Kahn - Reply
Past 24 Hours: 31
Past 7 Days: 208
Past 30 Days: 944
All Time: 88,499
