Xbox 360 Bottom Vent Replacement
  1. Xbox 360 Bottom Vent Replacement, Bottom Vent: step 1, image 1 of 1
    Tool used on this step:
    Xbox 360 Opening Tool
    Buy
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
  2. Xbox 360 Bottom Vent Replacement: step 2, image 1 of 3 Xbox 360 Bottom Vent Replacement: step 2, image 2 of 3 Xbox 360 Bottom Vent Replacement: step 2, image 3 of 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  3. Xbox 360 Bottom Vent Replacement: step 3, image 1 of 2 Xbox 360 Bottom Vent Replacement: step 3, image 2 of 2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  4. Xbox 360 Bottom Vent Replacement: step 4, image 1 of 2 Xbox 360 Bottom Vent Replacement: step 4, image 2 of 2
    • Repeat the same process to release the two center clips on the bottom vent.
  5. Xbox 360 Bottom Vent Replacement: step 5, image 1 of 2 Xbox 360 Bottom Vent Replacement: step 5, image 2 of 2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  6. Xbox 360 Bottom Vent Replacement: step 6, image 1 of 1
    • Remove the bottom vent from the 360.
68 other people completed this guide.
One Comment
cool thanks for the tip
exavier smith - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 89
All Time: 28,162
